How to fix/clean 348 (maybe others) Window Switches | FerrariChat
Discussion in 'Technical Q&A' started by mj_duell, May 19, 2012.
  1. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    #1 mj_duell, May 19, 2012
    O.K., So I woke up this morning with some ambition after a full night out with the wife at the casino. Consider this my penance.
    After reading a couple posts on 348 window switch replacement and the hassles involved in finding inexpensive replacements I decided to write up a little "How To" on the fixing and/or cleaning of the switch before you spend the money on a new one. The switch is actually very basic and it was made by TRW/Torrix who also makes these same switches for Land Rover, that is how I became familiar with their repair. It is very easy and straight forward.
    1. Take the switch body a part. This is very easy but can get harder if you don't go slow and use shims or in my case a flat head screw driver and dental pick, one of either side at the same time. this will release the tabs holding the parts together. Do not pry to hard at the sides so you do not break the plastic.
    2. Pull out the switch mechanism and look it over for melting, breakage etc. If it is not broken then continue.
    3. Take the bar the the end of each end of the switch and pull back on the spring to release the actual switch plate on either side. You may have to carefully move the LED light out of the way for one side. Also, before you do this note the position of each plate in orientation to the switch body for reassembly.
    4. Now that the plates and springs are removed carefully clean all the major contact points including the plate pivots for the switch (red circles). Remember that the switch makes contact both at the top and bottom of the center contact stand so you must clean underneath as well. I like to clean all of the metal in the switch using electronic parts cleaner and emery or a small very fine brass brush.
    5. Prepare to reassemble. I find it easier to reassemble the plates by using needle nose pliers. You can then pull back the spring by hand. If you have moved the LED remember to move it back to where it was when you started.
    6. Just slide the mechanism back into the switch cover until it snaps and then go test the switch!
    The whole operation takes about 25 minutes per switch and can save you the wait time and the money to replace it. I hope this was helpful.
    --Mike
    FloridaIsland348 likes this.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Great thread Mike!
  3. porphy
    porphy Formula 3
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
    In the inimitable stooge style of Ernie. Great post and thanks. Already recuperated an old switch that stopped working and was replaced.
    Thanks much.
  4. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    No problem. I have 3 recuperated switches ready for when the next "new" one fails too. You can never have enough spares I guess. Anyway, I am glad this thread helped.
    Thanks,
  5. PAP 348
    Dec 10, 2005
    100,216
    Mount Isa, Australia
    Pap
    Thanks Mike, I just remembered the passenger side window 'up' switch doesn't work.
    I will remove and clean asap and hopefully that fixes it. :)
  6. porphy
    porphy Formula 3
    1,209
    Randall Gatz
    What is the relation between An Sor and Torrix? I thought that Torrix went out of business about 1993? I saw AnSor switches for sale on line. Your pics show an An Sor switch?
    Any clarification would be appreciated.
  7. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    My assumption is TRW/Torrix as they are exactly the same layout as some other switches I have from Land Rover. They do say AnSor on the case, you are correct. I have tried for a long time to match them with other manufacturers and I was unable to even come close. If you have a AnSor switch and can disassemble it and show that it is a usable replacement that would be great. The purpose of this thread is to show how to fix what came OEM, but I am sure people here would love an alternative it it was available.
    --Mike
  8. porphy
    porphy Formula 3
    1,209
    Randall Gatz
    These are not exactly the same but there are some matches. I have not checked the dimensions either but they look to be in the ball park. I guess they are not stock but are close. For those who have no other choices.
    http://www.regswitch.com.au/Ansor%20PDF.pdf
  9. AceMaster
    Feb 6, 2009
    34,776
    Ontario, Canada
    The switch that controls the passenger window on the driver's side will bring the window up but will not lower the window. I was wondering if that was the wiring or the switch that would be the problem.
  10. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    pop the swich panel out using knife or screwdriver and swap it with another switch - youll soon know :)
    my guess its the switch
