How to get access to the front light assembly | FerrariChat
Discussion in 'California/Portofino/Roma' started by Dohangs, Aug 28, 2016.
  1. Dohangs
    Dohangs F1 Rookie
    Oct 31, 2008
    3,113
    Florida
    Spiro
    Hi there
    Does anyone know how to gain access to the front light assembly. I noticed one of the little jewels (bulbs) fell off. Is there a way to open it up? I hope so, but knowing Ferrari, there is no way to gain access so you'd have to pay for an entire light which probably costs around $7000.
  2. doccharlie954
    doccharlie954 Formula Junior
    Jul 27, 2010
    256
    First you have to take off the wheel, front bumper, plastic piece inside engine, then you have access to the light. You will have to find some one to split the light in half and reglue the jewel back on put it all back together. Check with your dealer as my dealer splits them when they get foggy inside. They charge $1,200.00 for this service.
  3. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #3 4th_gear, Aug 28, 2016
    It's not that difficult to remove the headlight unit from the car by removing the gravel guard from the wheel well (see attached photo showing 3 attachment points) but putting the LED(s) back in place would be another matter. I imagine the only possible way to do that is to somehow remove the clear lens in a clean fashion to gain access and then either reinstall the lens cleanly or somehow obtain and install a replacement lens.
    I think the whole issue of the LEDs falling out is frankly outrageous and Cali owners dread this happening to them. This defect really should qualify a RECALL ITEM.
    Beach Boy and MadhuAF1 like this.
  4. doccharlie954
    Jul 27, 2010
    256
    The only way to remove this headlight is TO REMOVE THE ENTIRE FRONT BUMPER. MY headlight had to be fixed and I was there at the Ferrari body shop when it being replaced. You cannot do it any other way PERIOD. You just can't remove the plastic fender liner and expect to fix it that way. Just won't work. It has to be done the way I described in my above post.
  5. Dohangs
    Dohangs F1 Rookie
    Oct 31, 2008
    3,113
    Florida
    Spiro
    Thanks for the Iformation. I was going to see if my guy can fix this but I may just let the dealership do it.
  6. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #6 4th_gear, Aug 28, 2016
    You're right.
    While the 3 tabs are indeed for mounting the headlight unit, the screws are shown fastened from the top and the front rather than from the opposite directions, as you can see in the headlights diagram I took off the Ricambi website. While those 3 tabs would appear to be much easier to access from the wheel well as shown in the second drawing. It's unfortunate the procedure requires removal of a major externally visible panel as well as the plastic apron inside engine compartment.
    Thanks for the correction and clarification.
    Beach Boy likes this.
  7. glob1971
    glob1971 Formula Junior
    Jul 3, 2011
    442
    Czech Republic
    I have the same problem on my Ferrari California, those little jewels (bulbs) are falling off.
    Do you know if this is covered by the power warranty ?
  8. rocketman
    rocketman Formula 3
    Oct 1, 2009
    1,487
    NY & Miami
    Please post a pic of the defective bulbs (jewels) that you are referring to.
  9. Dohangs
    Dohangs F1 Rookie
    Oct 31, 2008
    3,113
    Florida
    Spiro
    Sorry, I don't own the car anymore. Don't have a picture
  10. Paul Adams
    Paul Adams Rookie
    Sep 12, 2018
    2
    Palm Beach
    Paul Adams
  11. MadhuAF1
    MadhuAF1 Rookie
    Sep 20, 2020
    3
    Madhu Aiyappen
    Paul, Did you get an estimate to fix? I am facing same issues.
  12. MadhuAF1
    MadhuAF1 Rookie
    Sep 20, 2020
    3
    Madhu Aiyappen
  13. 355Aloha
    355Aloha Karting
    Feb 15, 2004
    120
    Honolulu Hawaii
    John N
    HI
    What dealer took the unit apart.
  14. 355Aloha
    355Aloha Karting
    Feb 15, 2004
    120
    Honolulu Hawaii
    John N
    HI
    What dealer took the light apart, I might have to send my lights to them or have my dealer contact them
  15. MadhuAF1
    MadhuAF1 Rookie
    Sep 20, 2020
    3
    Madhu Aiyappen
    I have not been able to get an estimate yet. Sorry to heatr that you are having same issue. I wish Ferrari does something about this as there is no guarantee that after you fix another one does not fall off : ( I will keep you posted.
  16. 355Aloha
    355Aloha Karting
    Feb 15, 2004
    120
    Honolulu Hawaii
    John N
    I have watched videos on Youtube, they all show putting the headlight of a pice of wood in the oven for 12-15 min at 180-200 degrees.
    But the issues are, we can not remove all lights like they recommend in the videos, so back to the heat gun option.
