How to get rid of Check Engine Light for Cats on 360? | Page 3 | FerrariChat
Discussion in '360/430' started by arachnyd, Aug 18, 2018.
  1. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    Is that where the position of the downstream sensor is further back along the catalytic converter ... toward the muffler ... which provides a greater length of catalyst material for the exhaust gas to pass through before reaching the sensor?
    Steve
  2. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    Yes
  3. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,597
    Yes
  4. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    Just keep clearing the codes ..... it will eventually just go away and all will be fine. Car is better without cats.
  5. Skidkid
    Skidkid F1 Veteran
    9,648
    Campbell, CA
    John Zornes
    What are you smoking? Why do you think that it will magically stop throwing a cat efficiency code if you reset it enough times?
  6. one4torque
    one4torque F1 Veteran
    5,794
    Houston
    One4torque
    radlu - are you saying it will eventually adapt to no cats? do you have exp with this? or just conjecture? thx.
  7. radlu
    Jun 6, 2005
    424
    Yes. Exactly. Will Adapt. Try resetting the battery. Worked for me.
  8. mello
    mello F1 Veteran
    5,541
    CA Bay Area
    Steve
    You do not know what you're talking about. You need to stop spreading misinformation. You are doing a disservice to the Ferrari community by presenting fiction as fact.
    Skidkid, f355spider and mchas like this.
  9. Skidkid
    Skidkid F1 Veteran
    9,648
    Campbell, CA
    John Zornes
    I am sure that disconnecting the battery cleared his code … for a while. It doesn't solve the issue just clears the codes.
  10. one4torque
    5,794
    Houston
    One4torque
    skid - I was wondering if the ecu could adapt to no cats.... if there was enough range in the st and lt fuel trims and data-tables to adapt to no cats...... I presume that is not the case. Strange thing we are just talking about pre-cats.... and not the primary cats...... a rather finicky program in these f cars.
  11. Skidkid
    Skidkid F1 Veteran
    9,648
    Campbell, CA
    John Zornes
    Definitely not enough range in lt & st trim. It is a solid system and not really troublesome. The trouble is when you start trying to bypass the emissions systems, THEN you have issues with a CEL. Funny, that is exactly what it is designed to do; as is every other car in existence.
    The precats are there to meet cold start emissions, they have virtually no impact on warm running emissions. Since it was for the US only Ferrari just used the systems they had and made a tweek to the monitors. The range is fairly tight but it checks that cat's efficiency, like all of those monitors. Since there are 2 monitors you get an error when you remove either of the cats. A fairly tight range makes it more difficult to trick the system, but not impossible.
  12. Mercedes
    Mercedes Karting
    May 1, 2018
    67
    Orlando mercid
  13. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    913
    S La
    Remove the CEL bulb.
  14. Mercedes
    Mercedes Karting
    May 1, 2018
    67
    Orlando mercid
    Lol .just wondering if any one used the magnum simulators any thoughts? Its like a resisitor which sends the singnal back that everything is fine..
    Sent from my LM-X210(G) using FerrariChat.com mobile app
  15. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    I've entirely eliminated CEL for cats by coding the calibrations within the Ignition ECUs using my latest Swiss Army Knife tool.
    It's a guaranteed way to ensure absolutely no cel for cats ever. If you still need to pass emissions you can leave them coded in but adjust calibration for sensitivity of min/max thresholds.
    I can do this for both F430 and 360's...
  16. Mercedes
    Mercedes Karting
    May 1, 2018
    67
    Orlando mercid
    Where are you located.what is the cost? Here in florida no emission testing.
