How to get that perfect (enough) timing during rebuild | FerrariChat
Discussion in 'Technical Q&A' started by DanielGA, Jul 7, 2019.
  1. DanielGA
    DanielGA Karting
    Mar 19, 2018
    193
    Midwest
    Daniel A.
    All,
    I am rebuilding my Mondial 8's 2V engine (=308 2V engine). See attached pics. In pic, cam covers, intake and plenum and not secured yet -- just for show :)
    Now, I need to get the perfect timing. I tried to find the "middle" of TDC and its quite near the PM1-4 mark (using a wooden stick in cylinder 1 I found where the stroke starts going up and down, then the found the middle, which is as seen in the pic). I then turn all 4 cams manually to line up their marks perfectly. But because of the limited teeth in the timing belt I can get all marks on the cams to appear a little "before" or a little "after" a perfect line-up. I choose a "little" after thinking that corresponds to some slight advance (I estimate of 2-4 degrees).
    Is this the best that can be done? See pics.
    I know some say I should use a degree wheel and I might after my upcoming trip (and learning how to use a degree wheel).
    Any thoughts?
  2. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    It's so easy right now with the engine out of the car to do it exactly. Buy a degree wheel and a dial indicator and get it spot on.
    A wood stick does not replace a dial indicator, LOL
    INTMD8 and waymar like this.
  3. absostone
    absostone F1 World Champ
    10,176
    Your pointer on the flywheel should be on the PM1-4 mark. Im sure some of our Honored Fchat Pros will chime in soon
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    1) best way, use a degree wheel, and ignore the flywheel mark.
    2) second best way, use the mark (and it is not the one you are on now). It should be the | mark to the left of the PM14 word.
    3) and then line up all four assembly marks on the cams with the cam caps | marks.
    In the end, the 2V engine is not all that sensitive to perfect cam timing (because of its 2V design) so you will not really notice any difference. But, you will get to claim "I degree wheeled my cams"
    Best wishes.
    Wade, absostone and f355spider like this.
  5. Steve Magnusson
    26,932
    #5 Steve Magnusson, Jul 7, 2019
    No:
    1) the position of the cam sprocket can be adjusted relative to the cam using the pin and pattern of holes (under the washer and large bolt holding the cam sprocket to the cam), and
    2) the cam sprocket can be moved relative to the (fixed) belt (when the crankshaft is at 1-4 TDC) by skipping teeth.
    Using these two "adjustments" gives a resolution of 1 deg for each cam to the crankshaft per this chart (your 2Vi is a "late 308" with 3 holes in the cam flange and 5 holes in the sprocket):
  6. GordonC
    GordonC F1 Rookie
    4,166
    Calgary, AB, Canada
    Gordon
    Agreed, from your photos you are a long way off the best possible cam timing from just using those timing marks - you should be able to have them all exactly lined up. See yelcab's comments above about the flywheel mark, and Steve's comments in the following post about using the cam sprocket pegs to align the cams.
    You can do much better!
  7. Motob
    Motob Formula 3
    Nov 11, 2003
    2,389
    Frederick, Maryland
    Brian Brown
    You have the engine out of the car. It is very easy to mount a degree wheel to the crank hub and do a proper check of the cam timing, rather than just trying to get the marks close. Your timing is way off now at the cams and are using the wrong mark AF2 at the flywheel instead of the PM1/4 mark. Also, you should check cam timing with the crank hub/harmonic balancer installed and the crank bolt somewhat tight, as you can get timing gear movement on the crank, causing timing errors.
  8. tbakowsky
    Sep 18, 2002
    20,042
    The Cold North
    Tom
    You are not tensioning the belts correctly.
  9. DanielGA
    DanielGA Karting
    Mar 19, 2018
    193
    Midwest
    Daniel A.
    Thanks all! By reading here, and then elsewhere in forum, I learned about the cam gear pins and the ability to finesse timing by changing the relative cam gear location. Great! I think I will "degree the cam" as well. Read up on that. Definitely needs improvement and might as well do right since trivial to change now.
    Will get to in late July!
  10. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    I’m afraid I have disagree with my esteemed colleagues....
    The purpose of the cam marks is to keep “stuff” from crashing during final assembly/cam timing...once this is done, there ought to be a “chisel” stamp found at the END of the cam and the end cap-this. This WAS the marking done at the factory.
    A couple of observations: considering how cheap they are, and lubricating oils and additive packaging being such a contentious topic with a huge hosts of opinions: for $4-5 bucks each: get new adjustment “pads”, as there are clear wear holidays visible in your pictures.
    That said: MAKE a tool using an “Apple cored” spark plug and a welded and tip radiused steel insert-this will allow you to obtain TRUE TDC. Forget flywheel marks-using a degree wheel, and a pointer, after installing your “tool”, SLWOLY creep up from one side until it “locks up”, reverse direction, do the same thing. Split the DIFFERENCE, adjust the degree wheel in whichever direction is appropriate,and repeat-several times, until the degree number clockwise and counterclockwise is EXACTLY the same
    Now you have true TDC....
    PRIOR to this-using the stock cam chisel TDCMarks, make the valve lash EXACTLY .020” or 1/2 a MM( check the spec in your manual, since my stroke, I am no longer 100% confident in memory recall-so...ALWAYS measure 3 times and cut ONCE: same for specifications...
    That said: use go/ no go feeler gages, sacrifice four pads and have the back sides PRECSION ground to the EXACT clearance required for both intakes and exhausts to be timed.
    With another CAPABLE assistant who can follow directions: start rotating engine SLOWLY such that YOU can rock the bucket in a circular fashion so that as SOON as it tightens up: you yell STOP!
    Record your degree valu, then continue until it resumes rotation at CLOSING, yell stop, record value, adjust came timing as is necessary
    REPEAT the process
    It won’t be any more accurate than this!
    Once done-CK it numerous times if you are a first timer at this process-then swap out the machined pads for stock lash value pads and you are done-the comp car method(old GES guy taught me this decades ago)
    Good luck
