360 - How to get the 4-digit PIN code found inside 360's alarm control unit? | FerrariChat
360 How to get the 4-digit PIN code found inside 360's alarm control unit?
Discussion in '360/430' started by OceanSide760, Jan 23, 2022.
  1. OceanSide760
    OceanSide760 Karting
    Jul 8, 2009
    185
    Hi all. Does any one know how to get the 4-digit PIN code found inside your 360's alarm control unit?
    Thank you.
  2. OceanSide760
    Jul 8, 2009
    185
    * Also is this ALARM CODE the same as the RADIO CODE?
    TY
  3. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    345
    Bay Area
    NO, They are different codes. The Alarm Code is on a small document that came with the car under a "scratchy" area. Check with the manual and other papers you got... You may be lucky and find it (I did)
  4. Qavion
    Qavion F1 World Champ
    14,088
    Ian Riddell
    Do you have a working red (master) fob?
  5. OceanSide760
    Jul 8, 2009
    185
    Yes, and I opened it up and no code written inside, thanks
  6. Qavion
    14,088
    Ian Riddell
    Forum members like @gobble (in the USA) and @eric355 (in Europe) can extract the pin from the fob.
    Mark "Gobble" also sells the combined key/fob.
  7. OceanSide760
    Jul 8, 2009
    185
    Thank you, if you don't mind, can you show me what the doc looks like? "without your code of course :) "
  8. tazandjan
    39,084
    Here you go. Photos inside and also an explanation of the fobs. Mark (gobble) can pull your PIN for you from your red fob or your Alarm Immobilizer ECU if you cannot find it in your document folder.
