How to identify a 94-95 348 engine | FerrariChat
Discussion in '348/355' started by Night life, Nov 25, 2009.
  1. Night life
    Night life F1 Veteran
    7,311
    The city that rhymes with fun in Canada
    Roberto
    #1 Night life, Nov 25, 2009
  2. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    Please dont buy that engine in those pics Roberto. :):)
  3. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    The plastic covers were an "update" from the aluminum ones. It looks like the engine in your pics is an '89 or '90 - it only has one throttle position sensor, making it a from a Motronic 2.5 (early) 348.
  4. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    The later engine has higher plenum ridges on it.
  5. Night life
    7,311
    Roberto
    Really why would they go to the plastic one brutal, I noticed it had one missing too, thanks for your response very insightful of you.
  6. Night life
    7,311
    Roberto
    I wont now, but why? I must ask ;)
  7. PAP 348
    Dec 10, 2005
    100,232
    Pap
    You dont have to look hard to see that everything but the throttle-bodies are left open to atmosphere. Imagine how much dust/dirt/crap has gone into that engine while sitting there? :D:D
    Especially the pipe that goes into the engine for dry sump oil system. ;);)
    It may be new, but probably has 10 yrs taken off its life by sitting there open like that. :D:D
    Ive seen reco/exchange engines sit for a few years too open like that and when we pull them down to inspect, there is plenty of dirt chunks in there, dust, surface rust, spiders and spider webs. :p:p
    And these engines were sitting in shops too. Not out in the yard by the looks of that engine. :D:D
  8. Night life
    7,311
    Roberto
    No this was in storage but you still make some interesting points, thanks Brother :)
  9. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Ok, cool. :):)
    If you DID decide to buy it, I would pull it apart and have it inspected and cleaned man. It doesnt take long to get **** in there that could cause engine failure or shorten the life of the engine. :):)
    Who knows how long it has been rebuilt and sitting there like that? :):)
  10. Night life
    7,311
    Roberto
    I think I am passing on this engine I want a 94-95, I have one on hold now ready to be shipped to me as we speak, it has less than my original engine and they are throwing in a seal kit, timing belt, oil filter, talk about good customer care.
    As soon as the deal is made I will post the name of the Co. (hopefully it wont be deleted :D), they have two other engines there if others are interested and they are straight up shooters.
  11. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Sweet man!! Thats the way to go. :D:D
    I hope they have it sealed up as best they can? ;);)
  12. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,180
    Australia
    Paolo
    see Roberto
    Pap is back and helpful as always
  13. Saint Bastage
    Saint Bastage F1 Rookie
    Jun 1, 2007
    2,548
    Connecticut
    Lane
    #13 Saint Bastage, Nov 25, 2009
    I second everything he said...Thats an older engine. Sucks that they changed from aluminum to plastic but true. Understanding and accepting Pap's comments, I might like the older engine. They are virtually identical except the aluminum covers and motronic 2.7s that you can transplant from your engine. I'd rather have the aluminum.
  14. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    Others have stated before (I think Ernie) that aluminum timing covers came in the very early 348s. The later cars have been downgraded to plastic. How much is the asking price for a good clean used 348 motor?
  15. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    The early cars did have aluminum cam belt covers.
    The engine is a '89 -> early '90 for sure. The two dead give aways are the single throttle position sensor, and the alternator support bracket for a Delco alternator. The other thing that engine is missing is the idle air control valves on both sides of the plenum. If you look on the back side of the heads you will see the casting year inside a little circle. On my heads it says (90) so that's the year heads were made. You can look under the rear intake cam sensor, or on the other head just under the rear cam seals.
  16. Night life
    7,311
    Roberto
    Brotherhood rocks, Thanks :)
  17. GeorgW
    GeorgW Karting
    Jan 31, 2004
    103
    Germany
    Georg
    Hi,
    You should verify the engine´s type and number, they are located near the oilfilter.
    For a 300 hp 1993 engine the type should be "119G" and the number should be above 33000, the type of the 1994 320 hp version should read "119H".
    Regards, Georg
  18. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    The "H" engines have a 10.8:1 compression ratio as compared to the normal 10.4:1 in the "G" engines.
    Again the engine in question here is NOT an "H" block.
  19. Saint Bastage
    Jun 1, 2007
    2,548
    Connecticut
    Lane
    Hmm...I learned something.
    I was not aware of a compression change in the newer engines. I thought the HP increase was due to an exhaust change.
  20. GeorgW
    GeorgW Karting
    Jan 31, 2004
    103
    Germany
    Georg
    Correct, the engine at the picture seems to be a Motronic 2.5 version, so it is the "F 119D" type. All M2.5 and early M2.7 348 engines are "D" types. Later M2.7 engines are "G" types and the last 320 hp versions are "H" types. Both engine type and number are stamped on the block near the oilfilter, very easy to verify.
    Regards, Georg
  21. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    Find an H engine and see if you can buy the aluminum covers off the one pictured - now that would be the way to go! :D
  22. Llenroc
    Llenroc F1 Veteran
    5,559
    Colorado
    Vern
    #22 Llenroc, Nov 26, 2009
    Just to add to George's comments the 320 "H" was not used in the '93-95 US cars, also the intake plenum was larger and had a different rib/fin design than the earlier plenum. The US cars came with the "G" engines in '93-'95(312 HP).
  23. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,073
    Pocono Sportscar
    Jim McGee
    "H" spec engine was only euro. was not homolgated for usa.
    Regards, Jim
  24. AceMaster
    Feb 6, 2009
    34,787
    Ontario, Canada
    +1
  25. ricardo teixeira
    ricardo teixeira Formula Junior
    Sep 2, 2009
    356
    Luanda / OPorto
    Ricardo Teixeira
    That's the tell-tale that I usually also look for....
