News
How to Inflate a Tire with WD40
Discussion in 'General Automotive Discussion' started by REMIX, Mar 24, 2009.
  1. To remove this ad click here.
  2. Buzz48317
    Buzz48317 F1 Rookie
    Dec 5, 2005
    2,803
    Shelby Twp., MI
    Michael
    Very cool...still sounded like it was leaking though.
  3. agup48
    Apr 15, 2006
    26,282
    Phoenix
    AG
    I like the Top Gear version...
  4. mattymouse33
    mattymouse33 F1 Rookie
    Oct 25, 2004
    4,579
    We'll set aboot ye!
    Matthew
    Could that be done with a normal tyre?
  5. lmpdesigner
    lmpdesigner Formula 3
    2,086
    Atlanta Georgia
    Brian Willis
    Standard tire shop procedure for a tire--We used starter ether fluid.
  6. To remove this ad click here.
  7. scottyd
    scottyd Karting
    Jun 22, 2005
    97
    Lucan
    Scott Dietrich
    Yupp, seen this done many times. First time i seen it was with a tractor tire and a lighter, you need balls to do that. Big bang!!!
  8. Teenferrarifan
    Teenferrarifan F1 Rookie
    Feb 21, 2003
    3,047
    Media, PA
    Erik
    What exactly is causing that to inflate?
    Erik
  9. Meister
    Meister F1 Veteran
    5,445
    Duluth, MN
    The Meister
    An explosion is nothing more than a rapid expansion of material, in this case gas/fumes/vapor etc. The vaopr cuases enough high pressure to fill and inflate the space contained by the tire. That's my non engineering take on it.
    I would guess the hissing is the valve stem inards which they removed so it wouldn't shoot out and either be lost or shoot an eye out.
  10. SpecialK43
    SpecialK43 Karting
    Oct 12, 2007
    198
    Kzoo, MI
    K Russell
    Our commercial facilities use straight ether, which is the main source in many starter fluids. It is very safe in a controlled set-up, such inflating in a cage and using the correct tools.
  11. To remove this ad click here.
