Does anyone have a recommendation on how to jack up my GTS? I have a floor jack. Where do you put the jack stands? Pictures would be great. Thanks, Enzo
A quick search of the archives using the words "jack points" yielded these. http://ferrarichat.com/forum/showthread.php?t=167970 http://ferrarichat.com/forum/showthread.php?t=167938 They are for a 348 but the points are the same on the 355. Don't forget to run a search the next time, as TONS of stuff has already been covered. Anyway, hope these helped.
I don't remember the 355 looking quite like that. I used the rear factory point to raise one side. I then put a jackstand under the front jack point (I had made a wood pad that kept the twin metal pressed areas for being damaged. In the rear I used the frome rail all the way at the back, just in front of the flat pads. The rail was better for the jack stand. I'd take some pics, but I don't have the car anymore!
