How to keep my alarm fob corrosion free. | FerrariChat
Discussion in 'Technical Q&A' started by Kevin Rev'n, Apr 21, 2014.
  1. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,480
    Honolulu
    Kevin
    I have some 12 year old alarm fobs for my 360 that just seem to be so easy to corrode and have seen better days. I clean the corrosion off of the terminals and pop in a new battery and sure enough a couple months later I am starting to have signal strength issues. Then I am cleaning off the corrosion again. Is there a treatment I can perform to the contacts to get them like new again?
  2. Kevin Rev'n
    Nov 29, 2009
    24,480
    Honolulu
    Kevin
    Am I the only one who has fob contacts that corrode where the battery makes contact?
  3. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    I don't know, but I can say that both mine are 14 years old and they're nice and clean. But I'm also pretty sure the batteries have never been left in them so long that the batteries leaked; i.e. they've been changed as soon as they become weak.
  4. Heat Seeker WS6
    Heat Seeker WS6 Formula 3
    Nov 4, 2003
    1,704
    Milwaukee, WI
    John G
  5. Cribbj
    Cribbj Formula 3
  6. TZ 750
    TZ 750 Formula Junior
    Jul 18, 2009
    912
    I have the same problem with my 456 fobs.
    1) Remove the leather cover, which holds moisture
    2) Clean contacts with light abrasive, like a pencil eraser.
    3) Apply contact cleaner.
    4) Apply contact grease to repel air / oxygen.
    5) Keep a tool in the glove box to open the fob.
    6) Keep a spare battery with the tool.
  7. Kevin Rev'n
    Nov 29, 2009
    24,480
    Honolulu
    Kevin
    Thanks Guys, I can work with this info!
  8. tazandjan
    39,160
    Kevin- I put battery terminal spray, the red stuff, on a toothpick and coat the terminals. No problems, but then we did have 8% humidity last week.
  9. TZ 750
    Jul 18, 2009
    912
    Here in Florida,
    it was higher............
  10. Kevin Rev'n
    Nov 29, 2009
    24,480
    Honolulu
    Kevin
    I ordered 80 bucks worth of DeOxit products so I think I will be OK! LOL
    I will post up the results for closure!
  11. tazandjan
    39,160
    Kevin- That stuff has a lot more uses than fobs. Incidentally, I only use Duracell MN21Bs in my fobs because I have never had one of those leak. Have pulled out several other manufacturer's leaking batteries in used fobs that have passed through my hands.
  12. Cribbj
    Cribbj Formula 3
    Taz, I pulled my first leaking Duracell out of an LED flashlight the other day. Always thought they were "unleakable" but that bubble has now been burst too. Still think they're probably better than any other battery (as far as leakage goes).
  13. Kevin Rev'n
    Nov 29, 2009
    24,480
    Honolulu
    Kevin
    #13 Kevin Rev'n, May 6, 2014
  14. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
    if you can find a small silica gel package that will go inside the fob it will keep the moisture from corroding the contacts
    works good in storing cameras also, I have it in my waterproof camera cover to prevent fogging and corrosion
    look for the package in your vitamin or aspirin bottle they are usually small
