355 - How to measure battery voltage? | FerrariChat
355 How to measure battery voltage?
Discussion in '348/355' started by evo11, Jan 7, 2022.
  1. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Gentlemen,
    I wish you all the best in the new year and that your Ferraris never let you down
    Can you tell me how to measure the battery voltage in f355 without removing the wheel arch, the battery is always disconnected with the knob and I do not want to turn it on because the immobilizer control unit is disconnected due to programming.
    In the future, I want to lead the plus cable to the top so that I can charge the battery at any time
    Thanks K
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,664
    South East
    Jimmie
    I may be wrong but the 355 has a charging stud on the top of the frame in the engine bay which I think is connected even if disconnect off so logically you should also be able to measure the voltage between the stud & earth (see L8 owners manual)
  3. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Thanks for ultra fast reply :)
    unfortunately I don't have manual near :(
  4. Mike Morrissey
    Mike Morrissey Formula 3
    1,143
    Denver, Colorado
    Mike Morrissey
  5. Qavion
    Qavion F1 World Champ
    14,266
    Ian Riddell
    The positive stud in the engine bay is connected to the battery positive, but there is no negative. If the cutout is used, you isolate the battery negative lead from the chassis. You cannot charge or check the battery from the engine bay.
  6. greyboxer
    Dec 8, 2004
    12,664
    South East
    Jimmie
    'I may be wrong' - thanks correction !
    Qavion likes this.
  7. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    So no chance that I could check voltage operating under front hood?
  8. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
  9. Qavion
    14,266
    Ian Riddell
    That gives me an idea. In the case where you couldn’t access the CTEK pigtail, and since you also have access to the battery cutoff switch, it may be possible to stick one of the voltmeter probes on the battery side of the cutoff switch and the other voltmeter probe on one of the fuses in the frunk which is hooked up directly to the battery.
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,548
    San Carlos, CA
    Mitchell Le
    There is a stud on the subframe near the + terminal of the right hand side 12V connection. That is the Neg stud.
  11. Qavion
    14,266
    Ian Riddell
    Do you mean in the engine bay?
    That won't work if your cutout switch is in cutout and you're measuring across here:
  12. Ferrari Fanatic
    Ferrari Fanatic Formula 3
    Apr 2, 2003
    1,317
    SoCal
    Battery voltage is slightly meaningless, until you put a load on the battery and then see how far it drops. Are you trouble shooting an issue. Not being inflammatory just curious.
    Mike Morrissey likes this.
  13. Qavion
    14,266
    Ian Riddell
  14. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Battery voltage is the basic parameter that clearly defines whether there is a problem or not. I didn't start the engine for 4 months so I was curious about the condition of the battery
  15. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Mine is not like that it’s a 99
    If disconnect is off no connection to battery from the back
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    If you could do this that would work
    Mine cuts off the positive
  17. Qavion
    14,266
    Ian Riddell
    Is your battery fitted back to front?
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Not sure what you mean Ian
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    My batt is in the front pass side if that’s what you mean
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    If you mean orientation in the front it is the only way it could be mounted due to length of wires
    Qavion likes this.
  21. Qavion
    14,266
    Ian Riddell
    Your cutoff switch is attached to the positive terminal of the battery?
    (EDIT)
    Ah, makes sense
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    My charger is hooked in back and will not charge if cutoff is active
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I think so
    Would that be wrong according to the wsm
  24. Qavion
    14,266
    Ian Riddell
    Correct, but the cutoff switch is still attached to the negative terminal of the battery.
    Your engine bay charger is attached to both the positive terminal and the chassis. When the battery switch is in cutoff, the chassis is no longer attached to the battery, so the charger will not work. The positive wire remains attached.
    phrogs likes this.
  25. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Ok makes sense
    When we do this on our heavy equipment I think we always cut the positive but I can not remember the logic. I incorrectly assumed my car was the same
    Thanks for the correction
