355 - How to measure battery voltage? | Page 2 | FerrariChat
355 How to measure battery voltage?
Discussion in '348/355' started by evo11, Jan 7, 2022.
  1. 26street
    26street Formula Junior
    Jan 30, 2021
    473
    Westchester New York
    Mark k
    Taz heavy equipment can be either positive or negative most on the positive side because up to the early 70’s most equipment manufacturers would use a positive grounding circuit ( meaning the positive cable would go to the frame and negative would go to the fuses,starter and etc) not to common today but having a disconnect on the positive side stayed
    On most cars you will see the negative used for disconnect the thinking is that by having it on negative you will not be pulling high amps through a switch contact (when starting or charging) even though it is being pulled on the contacts of a relay lol
