How to open menu left side on Gtc4lusso? | FerrariChat
Discussion in 'FF/Lusso' started by Emirateshills575, Feb 1, 2023.
  1. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    How to open menu left side on Gtc4lusso? I didnt find button
  2. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    you do it with the dash control wheel that is on the left of the steering wheel. You need to be stationary to see most of the functions. While driving, you will have very limited choice in the menu.
  3. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    This buttons no works for me, maybe because of error "not programmed"
  4. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,560
    Longmeadow, MA
    Eric
    What are you trying to access?
  5. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Never mind, i cant open menu because seems BCM is not works correctly
  6. Bamsefar
    Bamsefar Formula Junior
    Nov 26, 2012
    524
    Charge your battery, or better yet, change battery. Unless your GTC4 just had service, since well there is that slim chance that your nav/radio is not in sync with the rest of the car.... This can happen during service.
  7. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    It looks like your car has been messed with... Like a mic mac of control modules were put together from different cars without being properly programmed. This, or a faulty wire loom. I'd get the dealer involved before it's too late, this could prove costly.
  8. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Alredy Flow checking wires, it shows wrong signal from BCM, i have else front right wheel touch arc, and hum sound after 100kmh from rear suspension, i changed alredy rear hub and arm. But engine and gearbox works well, 20k km only, hope i can solve and balance suspension.
  9. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    Could it be that this was a flooded car? That would explain the BCM issue, and possibly the damaged bearing from the rear suspension.
  10. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Not possible, this car from here Dubai, everything electronic works good, and interior and exterior in the good condition, it seems someone hit the curb, alredy changed rear left hub and arm
