How to press TO Bearing from Housing | FerrariChat
Discussion in 'Technical Q&A' started by Brewman, Mar 19, 2014.
  1. Brewman
    Brewman Formula Junior
    Apr 3, 2012
    417
    NC Mountains @ Boone
    Joe
    I need to replace the TOB on my 94 348. I do not see how to press the T/O bearing out of the housing. Search's here have turned up several threads where this has been done but no detail on how the backside of the bearing was accessed. I would appreciate any pointers on how to do this.
    Thanks,
    Brewman
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It is part of the slave cylinder. Typically serviced as an assembly.
  3. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
  4. Brewman
    Apr 3, 2012
    417
    Joe
    Thanks to responses from 2NA and 348Jeff. I agree Hill is a far superior bearing and my plan is to go in that direction. I'm dissecting the OEM part because I'm inquisitive.
    After cleaning the T/O bearing flange I found 2 small holes under the extensions the springs fit in. The holes go thru the flange to the bearing. By putting a drift pin in each hole the bearing pressed out with no problem using my shop press. The challenge now is to source a new bearing. I expect this will be a problem but planning a trip to the local bearing house in the morning anyway.
    Thanks,
    Brewman
  5. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
