How to program a key FOB and start car w/o FOB! | Page 4 | FerrariChat
Discussion in '360/430' started by rob4092xx, Oct 31, 2012.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Outstanding information.
    Thank you very much Taz!
    I will go to my local dealer this weekend and get this done.
    All the best to you always,
    Dan
  2. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Is the dash LED flashing? If not check the “anti-theft” fuse. If that’s not the issue try unplugging the siren. It’s on the other side of the firewall by the steering components in a 360.
  3. Skidkid
    Skidkid F1 Veteran
    9,505
    Campbell, CA
    John Zornes
    The answer is you can't reprogram the existing PIN. Mark's suggestions are pretty good, particularly checking the siren. On occasion a failure there will disable the system. It is likely that someone had one fob and cloned two more. That means they are really all the same fob. You can generally resyncronize a fob by pressing the button a bunch of times. I forget if it is 10, 13 or ?? but it is in that ballpark. Swapping between fobs will confuse the system if they are cloned.
    Can you start the car with your PIN? If you can, an option is to get a new fob with a PIN and reporgram the system. That would allow you to mate the black fobs you have (at least two of them). NOTE: some fobs have a black case but are really a master or red fob.
    Another option is to disable the alarm system. There are threads about it on here.
    How to program fobs and the limitations are in a doc. Do a search. There are literally dozens of threads with the file attached. Someone may even post it here but you never know.
  4. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    If you need to reload your fobs for some reason you can’t reload the same master. I can send you a “loaner” master to first reload it along with two blacks. You then get into learning mode a second time and relearn your existing master plus the same two blacks.
    I could also go through the fobs you have and make sure you have a good matched working set.
    brogenville likes this.
  5. tazandjan
    39,128
    Things are so much better than when I wrote that original document in 2008. Nobody knew how to find the PIN then and you were stuck with clones only if you could not obtain the correct original PIN. Mark now can start with basically nothing and provide a full set of fobs with PIN. Eric 355 and I managed to make a dozen of so sets of three fobs for owners in the olden days, but our method was OBE'd by being able to find the PIN in the alphanumeric read-outs from the red fob and Alarm ECU.
    Need4Spd likes this.
  6. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    We talked on the phone last night and I’m guessing he’ll be back here saying it was just the fuse.
  7. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Just got a text it was a blown 5 amp anti-theft fuse. Problem solved.
    Need4Spd and Skidkid like this.
  8. Dankow
    Dankow Rookie
    Aug 23, 2020
    18
    Buffalo
    Daniel Kowsky
    Gobble do you think you could help me out with a similar issue?? I’m new to this community just got my 360 last week. This immobilizer stuff is wild to me. Send me a PM if you don’t mind! Thanks in advance
    Dan
  9. eric355
    eric355 Formula 3
    1,221
    Toulouse (France)
    Eric DECOUX
    Old days, Terry ;)
    I know now how to recover the PIN from the red fob and from the alarm ECU.
  10. tazandjan
    39,128
    Eric- Yup, you and Mark can do it all nowadays, and without the sneaky tricks.
  11. Hexus
    Hexus Karting
    May 24, 2008
    50
    Moscow, Russia
    Mark is the best. Great support. Thank you.
