How to: Pull crankshaft seal | FerrariChat
Discussion in 'Mondial' started by schelle_pelle, Apr 1, 2023.
  1. schelle_pelle
    schelle_pelle Karting
    Oct 22, 2021
    197
    Berlin, Germany
    Hi,
    probably it's quite obvious, but I struggled a bit in the first place... How to pull a crankshaft seal on a Mondial 3.2:
    Basically it's the woodscrew method combined with a claw hammer and another hammer.
    Drill three holes with a 2mm diameter. Then screw three woodscrews with 5x100 dimensions in there. Not too deep, but maybe 2-3 turns. Then get the claw hammer and position it like shown on the pictures. When the position is stable get a 1-2kg hammer and hammer against the claw hammer in order to pull on the screw and therefore on the seal. Work yourself around the three screws bit by bit. If a screw gets pulled out of the seal just drill another hole right next to the old one and continue.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. moysiuan
    moysiuan F1 Rookie
    4,185
    Canada
    Nice to see the pictures of a successful removal!
  3. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    Yes, yes and yes.
    ( but, this is a mechanic, trade secret.,)
    Schelle,
    Thank you for posting.
