How to purge air out of cooling system? | FerrariChat
Discussion in '456/550/575' started by ItalianOne, Nov 2, 2021.
  1. ItalianOne
    ItalianOne Formula Junior
    619
    Mich
    Kevin R
    Watching my temp float around when I drive and believe I have a small air bubble in the cooling system. Is there a easy way to purge the air out on a 03 575? No over heating issues. Does the air bubble pass over the sensor then pass through the system? Is this why the temp moves up and down on my gauge??
  2. tazandjan
    39,191
    Yup, there is a bleed screw on the thermostat housing. Make sure you turn the heater on full when doing the bleed. Can help to raise the nose, but not strictly necessary.
    belfry likes this.
  3. ItalianOne
    619
    Mich
    Kevin R
    Thanks Terry.. I will look for it..
  4. 12659
    12659 Formula Junior
    Oct 6, 2005
    349
    Seattle WA. USA
    mark
    I've found that you can un-screw the header tank cap just enough so it vents freely then drive around with the heater on. It sort of burps itself.
