How to rebuild a power steering rack F355 | FerrariChat
Discussion in '348/355' started by yelcab, Nov 15, 2015.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #1 yelcab, Nov 15, 2015
    Jumping in head first, eff the torpedo. This is going to be a step by step instruction on how to disassemble, source the parts, and rebuild a TRW power steering rack on a F355.
    Very few of us will ever attempt the removal of said rack, let alone rebuild it. But for those who are absolute stooges and want to get knee deep in this job. Here it is, with pictures, and step by step instructions.
    First, start by removing the two auxiliary hydraulic lines from the housing to the rack.
    Second, with the rack on your bench, remove the side plate that keeps the pressure on the shaft against the pinion. Two allen screws, 2 shims, 1 paper gasket. Notice the last picture with the round pressure plug with the Teflon insert.
    ShineKen and Arturin like this.
  2. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #2 yelcab, Nov 15, 2015
    Arturin likes this.
  3. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #3 yelcab, Nov 15, 2015
    At the bottom of the housing, remove the pressed-in cap to expose the retaining nut for the pinion.
    1. You can pry it out. I could not figure that out in 30 minutes, so...
    2. I chose to weld in a nut, screw in a bolt, and a cheap slide hammer makes minced meat of this task. Pick your poison.
    3. Use an impact wrench, remove the nut.
    4. Use a brass drift, and a hammer to knock the pinion out. It comes flying out so be prepared.
    Arturin likes this.
  4. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #4 yelcab, Nov 15, 2015
    Then remove the two tie rods on both sides of the rack. I used a combination of two pipe wrenches on the driver side, and a large pair of channel locks with a pipe wrench on the passenger side. Both are right handed threads.
  5. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #5 yelcab, Nov 15, 2015
    Here comes a non-obvious step. You need to remove the 2 inch plastic plug at the end of the shaft.
    1. push that rack all the way into the housing. There will be a **** load of fluid that shoots out 6 feet streams so get plenty of towels to mop that up.
    2. Notice the elongated hole at the end of the housing on the passenger side. 1/8 in wide, 1/2 wide, with a head of a pin barely visible. That is the retaining pin you have to remove.
    3. Use a pair of needle nose pliers, insert the tips into slots in the plastic plug and rotate clock-wise (for me it was cw). The end of the pin will slide out, insert a flat head screw driver and gently pry the end over the edge of the housing, continue until you see the other side of the pin. You have to rotate over 180 degrees. Then remove the pin.
    4. Insert a slide hammer with a pilot bearing attachment into the plug, pull out the plug and the seal at the same time. There is no way to do this w/o a slide hammer.
    Arturin likes this.
  6. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #6 yelcab, Nov 15, 2015
    Now slide the rack out from driver side to passenger side, all the way out. Set it aside
    The picture shows the end of the rack, driver side, with the seal orientation (I put the seal back on the rack to take a picture of its orientation). Unlike a manual rack, the power steering rack has a solid round plate in the middle of the rack with seal on it so that the hydraulic fluid has something to push against.
    Arturin likes this.
  7. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #7 yelcab, Nov 15, 2015
    Now remove the seal at the other side of the rack. It is buried over a foot inside the housing and forget the Autozone pilot bearing puller, it does not work. I happened to have a smaller pilot bearing puller that worked for this task. I removed the hammer head from the shaft to get enough reach, turn the shaft to lock the pilot bearing prongs against the seal, and pry the end of the slide hammer against the shaft housing using a fork (a ball joint removal fork). Get the idea, this job is requiring all kinds of tools.
    Arturin likes this.
  8. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #8 yelcab, Nov 15, 2015
    Remove the circlip at the bottom of the pinion housing, turn the housing right side up, use a long brass drift, knock out the bearing from the top.
    Arturin likes this.
  9. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #9 yelcab, Nov 15, 2015
    Lock the steering rack in a bench vise, with the housing bottom up. There is a shaft seal that is half way down the pinion housing. It is retained in place by a spacer which is pressed in tightly.
    Use a MAPP gas torch, heat up the housing area where the spacer is, to about 250F, and use a brass drip and hammer to knock the spacer out. A few firm knocks and the spacer falls out of the housing expanded from the heat.
    Reach in and drive out the shaft seal from the housing. I had to destroy it to get it out. So be it. I won.
    Arturin likes this.
  10. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #10 yelcab, Nov 15, 2015
    That completes the disassembly process. I am taking these seals to an industrial supply house tomorrow to get replacement. So far, my research shows that a 95-97 Volvo 960 rack is nearly identical from TRW and there is a seal kit for that rack. Buy it at your own risk. I will buy it just to see if it fits.
    The link is: Volvo power steering Rack Kits / 960 Series / 95-97 / (Cam/TRW Design)
    The shaft seal which I destroyed has this part number from TRW: 34002485 which matches the dimensions to a Corteco seal p/n 12014254B. The picture below shows the two seals and the oring I will try to get from vendor. It does not show the Corteco seal above.
    Time to clean the rack, pinion, housing up in anticipation of re-assembly. More to come.
    Arturin likes this.
  11. WATSON
    23,798
    WI
    Wow. Fantastic! Thanks for this.
  12. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Very cool stuff man! You're making it look easy. :eek:
    I need to pull one side of my rack apart in my 348. The bush has collapsed and I am going to try and cheat by replacing it with the rack bolted in the car. ;)
    I think I can do it, hell............I can do anything! :D
    Looking forward to seeing more pics, thanks for sharing mate. :)
  13. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Great work Mitchel!
  14. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Why is it called a rack?
  15. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,617
    The Brickyard
    The Bad Guy
    Great thread Mitchell!!
  16. mosierjr
    mosierjr Karting
    Sep 29, 2009
    154
    Texas USA
    J.R.
    This is the kind of info that makes this forum great. Thanks for all the details and pics.
  17. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    Because it has two ... ends. I have to admit it was pretty flat for a rack. Very unmemorable.
  18. Qavion
    Qavion F1 World Champ
    14,422
    Ian Riddell
    Because it's an instrument of torture? :D
    Were there any signs of failure or wear/tear, Mitchell? What was the inspiration for this intrepid adventure?
  19. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    It was leaking out the broken boots, not much but leaky. Then I spent days getting the effing thing out and I sure as hell was not going to put it back without rebuilding it. Besides, we needed a thorough rack rebuild thread, complete with whether the Volvo seals will fit.
    Rotex in Gardena quoted "anywhere from $200 to $700 to rebuild it, plus $100 shipping. It just offended me to no ends. Nobody will source or sell me a rebuild kit, and at some point in time I just said eff it, I am doing this myself.
    I inspected the "rod" and it is in very good shape with no bad wear. The housing is also in good shape, just needs the seals replaced.
    Mark HT and ShineKen like this.
  20. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    Nice write up and pictures.
  21. 8500rpm
    8500rpm Formula Junior
    May 20, 2014
    546
    San Francisco Bay
    Chan
    Which F355 is this? :D
  22. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    The red one.
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Awesome, just awesome mine is gonna need fixing aventually. I am adding this to the diy sticky. Thanks Mitchell
  24. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #24 yelcab, Nov 28, 2015
    OK, the bad news is this company PSkits has terrible customer service. But the good news is the power steering kit for the Volvo is exactly what the F355 rack needs. There will be some left over bits, but this ain't no Volvo.
    First pix is the kit bag, second are the contents, and third is where the various seals go. The metal retainer ring is 3rd from the top. Below that is the small seal barely visible.
  25. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    #25 yelcab, Nov 28, 2015
    Arturin likes this.
