How to rebuild a power steering rack F355 | Page 2 | FerrariChat
Discussion in '348/355' started by yelcab, Nov 15, 2015.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    #26 yelcab, Nov 28, 2015
    Now the metal spacer goes on top of that seal. I measured the distance from the spacer to the top of the housing BEFORE I took it out, and it was 2.520 inch. So that is how far to install it. FIrst, toss the metal spacer in the freezer for 10 minutes. While you wait, heat up the housing where the spacer is supposed to go, to about 150F. Drop the metal spacer in from the top, drive it in place with a deep socket to exactly 2.520 inch (or whatever you previously measured the distance to be). Firm taps will do.
  2. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    #27 yelcab, Nov 28, 2015
    Install the white spacer into the far end of the rack housing. Drop it down, and then drive it in place with a socket and a 1/2 breaker bar as a rod.
    Then, wrap the rack teeth with saran wrap to protect the seal, install the seal on the far end of the rack (spring side facing the fluid side, not the grease side) then remove the saran wrap. Insert the rack with the seal into the housing and firmly push it all the way into the far side. The seal will be in the right position.
  3. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    #28 yelcab, Nov 28, 2015
    Prep the other end by installing the oil o ring on the large plastic plug, and push it on over the tip of the rack, and into the end of the rack housing. Position the plug so that the hole for the clip is visible through the hole in the housing.
    Insert the bent end of the clip into the hole, rotate the plastic plug (WD40 helps) until the clip slides all the way into the housing.
  4. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    #29 yelcab, Nov 28, 2015
  5. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    #30 yelcab, Nov 28, 2015
  6. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    #31 yelcab, Nov 28, 2015
  7. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    #32 yelcab, Nov 28, 2015
  8. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    #33 yelcab, Nov 28, 2015
  9. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    #34 yelcab, Nov 28, 2015
  10. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    #35 yelcab, Nov 28, 2015
    And that is the end of the illustrated steps. I will leave you gear heads to re-install the rubber boots (I got to get new ones), and refill the rack with ATF fluid using a syringe, then attach the hard metal lines with new copper seals.
    It is time for a glass of celebratory wine, left over from Thanksgiving.
    ShineKen likes this.
  11. WATSON
    24,014
    WI
    Nice. Very, very nice.
    Thank you for the time & effort to post.
  12. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Bravo!
    Well done Mitchell.
  13. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Great post :)
  14. PAP 348
    Dec 10, 2005
    100,245
    Mount Isa, Australia
    Pap
    Excellent job mate! Thanks for sharing. :)
  15. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
  16. RaginBull
    RaginBull Formula Junior
    Oct 24, 2006
    996
    Bay Area, CA
    Darryl
    Nice work Mitchell, I love these posts! :)
  17. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,824
    Lake Villa IL
    Great thread! Thanks for the details and pictures.
  18. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    So, I am finished with this rack and thought about keeping it as a spare. But I will not need it for ... a few years. I am going to throw it on the for sale section as an exchange service. You send me yours and I send you mine, no waiting.
  19. Fredmec00
    Fredmec00 Rookie
    Apr 11, 2016
    29
    Brazil
    Frederico Oliveira
    #44 Fredmec00, May 31, 2016
    Mitchell,
    I think you may be able to help me with an advice. I have a F355 and I found a massive play on my steering rod. The play does not come from the track rod end, but possibly from the inner rod. Driver side is fine, passanger side (right), is the problem.
    I circled in red circle the part I suspect the play comes from. I haven't taken anything apart yet. The picture attached was originally from you.
    Does that piece has adjustment? If not, can I replace just the inner rod without taking the steering rack out? I have been told that is a major job, tight access.
    Any help will be welcome.
    Thanks,
    Fred
  20. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    #45 SoCal1, May 31, 2016
    Never tired it so I dont know access
    You can try an inner tire rod removal tool
  21. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    Fred
    That big knob thing is round, and screws into the end of the rack. That part of it has no play. The other side of the knob is attached to the inner rod (the left hand side of that picture). If there is any play at all, you replace the inner-tie rod. There is no fix.
  22. Fredmec00
    Fredmec00 Rookie
    Apr 11, 2016
    29
    Brazil
    Frederico Oliveira
    #47 Fredmec00, May 31, 2016
    True, that play has to be removed and the inner tie rod has to come out. The movie below shows how bad the play is.
    https://youtu.be/eLS7EfUHP5o
    I don't think the removal tool SoCal1 has mentioned would work. That round knob thing has no place to grab. How can I unscrew it? See attached picture.
    I tried to turn it with a pressure plier but it didn't work. Maybe I should try harder, but I am not very experience with suspension and steering components, at least not as much as with engine rebuilds and major assembly maintenance.
    Thanks for your feedback,
    Fred
  23. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    You are going to have some access problem with the rack still in the car.
  24. Fredmec00
    Fredmec00 Rookie
    Apr 11, 2016
    29
    Brazil
    Frederico Oliveira
    #49 Fredmec00, Jun 1, 2016
    Good news folks, the inner rod from my F355 steering is out. It was tight, but manageable to remove with the steering rack in place.
    Mitchell, tanks for your guidance. Your thread and the specific advices motivated me to do-it-myself. The workshop manual does not mention much about this sort of service.
    This forum can be a great source of knowledge for DIY.
    Pictures attached.
  25. Fredmec00
    Fredmec00 Rookie
    Apr 11, 2016
    29
    Brazil
    Frederico Oliveira
    #50 Fredmec00, Jul 8, 2016
