How to Refuel an F8 .... without *#(&@(@$% | FerrariChat
Discussion in '458 Italia/488/F8' started by mjz, May 28, 2023.
  1. mjz
    mjz Karting
    Aug 3, 2007
    173
    Houston, Texas
    Michael
    O.k. - so it's time to refuel my new F8. I thought it would be simple (i.e. no gas cap to unscrew).
    I open the gas door and place the fill nozzle into the filler neck pushing against the pressure cap. I start to fill the tank and the nozzle clicks off almost immediately. I shift the nozzle up and down and only a few cups of gasoline manage to enter. After 10 minutes, I manage to get a few gallons of gas into the tank and give up. This sucks. Is there a "trick" to getting the gasoline to flow into the filler neck at normal flow rates without it stopping every few seconds. I know there must be an easier way to do this.
    DefunctNeurons likes this.
  2. Art138
    Art138 Formula 3
    Nov 22, 2007
    1,531
    Ft. Lauderdale
    First make sure it’s not a station pump issue. I find that inserting the nozzle a few inches works best. I have had this issue when the pump nozzle is pushed all the way in.
    DefunctNeurons and AD211 like this.
  3. mkraft3003
    mkraft3003 Formula 3
    2,366
    Tampa, Fl
    Just pull the nozzle a little bit out and not all the way in. Works for me.
    mdrums and AD211 like this.
  4. mkraft3003
    2,366
    Tampa, Fl
    Lol, our posts crossed and great minds…..
    Art138 likes this.
  5. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Fort Lauderdale, Florida
    Todd
    I put mine nearly all the way in and it’s fills fine… sounds like a pump issue with incorrect back pressure switch to me. Try another station.
  6. PMiranda
    PMiranda Formula Junior
    Jul 23, 2004
    630
    Austin, TX
    Even a different pump at the same station might work better.
  7. Pastaboy1980
    Pastaboy1980 Formula Junior
    343
    Rolling Hills
    Fra
    Lol do you drool as well?
  8. RamsHmb
    RamsHmb Formula 3
    1,214
    San Francisco
    James
    I have had this issue on other f cars but but not my f8. Sounds weird but I flipped the filler upside down and it seals perfectly, instead of the bottom of the handle pointing down, have it pointing up. I know it’s an odd fix but worked 100% of the time on my wife’s FF.
  9. AD211
    AD211 Formula 3
    Owner Rossa Subscribed Silver Subscribed
    Aug 19, 2017
    1,207
    South Carolina
    Andy
    Same on my Cali and 488, plus didn’t squeeze the trigger all the way. No issues though on my F8. Same pump. Definitely weird.
  10. Nsd991
    Nsd991 Formula Junior
    Jul 19, 2012
    538
    I can see myself trying this and spilling and spewing gas everywhere :(
  11. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,960
    St. Louis, MO
    Eric
    Just the tip.
    bball16 and mdrums like this.
  12. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
  13. Eric C
    Mar 20, 2009
    10,960
    St. Louis, MO
    Eric
    That's called rape.
    bball16 likes this.
  14. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
  15. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,370
    Also an issue on classic Lamborghinis.....the only consistent way to gas it up is to just barely press the handle and then modulate it by pressing further until you figure out where that shutoff limit is. The angle thing works occasionally (in fact there is a famous picture where a model in a bikini is holding the handle upside down trying to gas up a Diablo).
    It takes about 10 minutes to fill up a half tank (13 gal).
    RamsHmb likes this.
  16. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    933
    San Diego
    Rob Barry
    In CA my 458 will barely engage with the "vapor shrouds" on the nozzles so I add a grommet to make everything work. Other owners use the upside down method, but that never worked for me.
    DefunctNeurons, Praecox and Need4Spd like this.
  17. Pastaboy1980
    343
    Rolling Hills
    Fra
    Im the franchise player and we talking about filling, filling man but we talking about filling filing man its not funny to me to but we not talking about driving
  18. Pastaboy1980
    343
    Rolling Hills
    Fra
    Cmon man just take a viagra and stick it in
    Eric C likes this.
  19. Pastaboy1980
    343
    Rolling Hills
    Fra
    This never happens to my six speed car
  20. mjz
    mjz Karting
    Aug 3, 2007
    173
    Houston, Texas
    Michael
    That is a good idea. I will try it.
  21. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I do the same thing. Always works. Cali nozzles need the vapor collar to be pushed back slightly to enable the pump switch.
    AD211 and rob5819 like this.
  22. Ivan Drago
    Ivan Drago Formula 3
    Jul 14, 2021
    1,213
    Midwest
    Ivan Drago
    The west coast is like a different world to me, man. What the hell is that? I heard in Oregon, or Utah (can't remember which), you aren't even allowed to pump your own gas at most places.
  23. lumirock
    lumirock Rookie
    Feb 21, 2022
    3
    I’ve had the same issue with my F8 since delivery last year- aug 22. Spoke to my Ferrari dealer about it and he was aware of some F8 owners -not all- being affected by this.
    He has given me some tips on how to improve or lessen the problem. I’ve tried it a few times, however not all perfect but much quicker than before.
    - Put the nozzle about half way in
    - Turn the fueling head towards 8 o’clock
    - Keep the gas trigger about 3/4 of the way. (Don’t compress the trigger completely.)
    After a couple of times you get the hang of it. Works for me
    AD211 likes this.
  24. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Mine has been fine. I stuck it in all the way, pull and lock trigger and it only kicks off when full. Voila
  25. pninja005
    pninja005 Formula Junior
    Nov 10, 2010
    580
    Europe
    Works fine out of the box for me too.. never had any issue, weird.
