How to remove 246 rear brake disc? | FerrariChat
Discussion in '206/246' started by 246er, Sep 27, 2017.
  1. 246er
    246er Karting
    Jan 1, 2016
    84
    Herefordshire, England.
    Chris Sherwood
    Hi all, I'm overhauling my brake calipers and fitting stainless pistons and liners. 3 out of 4 of the discs are fine but one rear is pitted and I would like to take the opportunity to replace it.
    I can't see how it removes though so if anyone can assist I would be grateful.
    Thanks!
    Chris.
  2. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    Chris- If you are installing new "pistons" in your calipers then I assume you have already removed the rear caliper. Now unscrew the two cad plated wheel alignment studs on the front face of the disk between the threaded lug bolt holes. These two alignment studs secure the disk to the hub as well as assure that the disk lug bolt holes are aligned with the threaded lug holes in the hub.
  3. 246er
    246er Karting
    Jan 1, 2016
    84
    Chris Sherwood
    Mark, that's great! Many thanks,
    Chris.
  4. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    Glad to help Chris--- just happened to be also working on my rear calipers- adjusting the pads for the .004 clearance.
  5. 246er
    246er Karting
    Jan 1, 2016
    84
    Chris Sherwood
    Ah, looks like I need advice on this 4thou clearance too! I looked in the handbook in the changing pads section but could see nothing there. Can you kindly let me have some details please Mark, as I am also renewing the pistons and seals in the calipers.
    Thanks and kind regards,
    Chris.
  6. swift53
    swift53 F1 Veteran
    8,284
    E.S.
    Alberto
    Mark, what is this 4thou?
    Regards, Alberto
  7. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    .004" is the clearance that you adjust between the brake pads and rotors for the parking brake mechanism.
  8. 246er
    246er Karting
    Jan 1, 2016
    84
    Chris Sherwood
    I checked this question yesterday with the calliper refurbishers. They say the pistons should be moved into correct position via the adjusters on the outside of each pot, until they are just "kissing" the disc. (From Mark and Motob's posts above seems that the correct Ferrari spec is 4 thou clearance).
    They say a most important point is to connect up the handbrake cables BEFORE you bleed the brakes, otherwise you can find the pistons get disconnected inside the pot from the handbrake mechanism.
  9. 246er
    246er Karting
    Jan 1, 2016
    84
    Chris Sherwood
    Sorry, for clarity, above should read "pads should be moved into correct position by moving the pistons via the adjusters on the outside of each pot, until the pads are just "kissing the disc."
    (Or go for the 4 thou!).
