How to remove AC vent alarm LED | FerrariChat
Discussion in '348/355' started by Carmellini, Dec 27, 2020.
  1. Carmellini
    Carmellini Formula 3
    Jul 16, 2019
    1,004
    I need to remove the alarm LED in order to solder one of the wires that has dislodged. I can't move the lamp housing far enough rearward to remove from the AC vent. Is there a trick? The parts manual diagram tells me it does come out.....????
  2. Carmellini
    Jul 16, 2019
    1,004
    Ok...I got it out and repaired. A little nerve racking because it sits under a plastic clip that looks very breakable:
    Took a helper to hold the clip up as far as possible, and then I was able to twist the LED housing and pull up and out.
    Just as agonizing to get back in, but I did it and works perfectly.
    emac, Mike Morrissey and Qavion like this.
  3. 285ferrari
    285ferrari Two Time F1 World Champ Sponsor
    Sep 11, 2004
    20,971
    MD and NE
    Robbie
    The clip breaks easily, when putting it back in, if that clip breaks, it can be epoxied back on easily.
  4. Carmellini
    Jul 16, 2019
    1,004
    I was lucky to bend it without any breaking. One of those things you can feel you are bending it near its limit........I got lucky.
    285ferrari likes this.
