488 - How to remove B-Pillar speaker grill on HiFi system | FerrariChat
488 How to remove B-Pillar speaker grill on HiFi system
Discussion in '458 Italia/488/F8' started by up4speed, Nov 30, 2023.
  1. up4speed
    up4speed F1 Rookie
    3,697
    Long Island, NY
    Chris
    Hi Guys,
    I just purchased a 488 (I still don't have it, it needs to be shipped).
    One flaw that I would like to fix, is the speaker grill that seems to be chipped from the seat belt hitting it .
    From what I understand, it's very common, but little things like that annoy me because I'm very anal with my cars.
    I looked up the part, and it seems to be only about $50, but I was wondering if it's easy to remove. I obviously haven't looked at it yet, but was wondering if anyone knows how to remove it? I'm sure it's easy, but want to make sure I don't damage anything in the process.
    Another option I considered, is that if somebody knows the exact paint color match, I think I can use a really fine brush to touch up the spots, and they would probably never show.
    Any recommendations?
  2. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,861
    San Jose, California
    It's most likely similar to the 458.
    Eric C likes this.
  3. up4speed
    up4speed F1 Rookie
    3,697
    Long Island, NY
    Chris
    Thanks for the info!
    Hopefully the 488 is the same (it should be), because that's very easy.
  4. RS458
    RS458 Karting
    64
    Arizona
    No idea about the exact color but my go to flat black for anything is BBQ paint. Maybe do a spray test and see if it matches.
    up4speed likes this.
  5. up4speed
    up4speed F1 Rookie
    3,697
    Long Island, NY
    Chris
    When I look at the pic closely, I think it may be more of a dark charcoal satin though. But like you said, I probably need to experiment with a few samples and pick the closest one. I have a feeling that I'm just going to replace the part though. I will update this thread with what I decided, so I can hopefully help others as well, since I know it's a common problem.
  6. up4speed
    up4speed F1 Rookie
    3,697
    Long Island, NY
    Chris
  7. Wolfman88
    Wolfman88 Rookie
    Feb 28, 2022
    3
    Wolf Schynoll
    I am having the same issue as you did with the speaker grill having small scrapes. Can you provide more detail on the paint color you used? Spray paint for metal? What brand? Specific color name? Any further details to help me get the same result as you did would be greatly appreciated. thanks
  8. up4speed
    up4speed F1 Rookie
    3,697
    Long Island, NY
    Chris
    It was just a regular Satin black automotive touch up paint in a bottle with a brush (see attached photo).
    I purchased from e-bay, I tried to find it for you on e-bay, but I can't find the exact one.
    I used those jewelry magnifying glasses so I could work accurately, and a really fine brush, and carefully touched up all the shiny spots. The color isn't an exact match (the car may be a little more charcoal I think), but it looks WAY better, and it doesn't catch your eye when you look at it.
  9. Wolfman88
    Wolfman88 Rookie
    Feb 28, 2022
    3
    Wolf Schynoll
    Thanks. Appreciate the quick response. I'll look at all options and hopefully find something that matches really well. Thinking of using a metal spray paint and just covering the whole grill to give it an even coating. I'll just tape off the door so I don't need to remove the grill. I have several grills to paint......door and by the seatbelt.
  10. up4speed
    up4speed F1 Rookie
    3,697
    Long Island, NY
    Chris
    I wouldn't spray it because it's a speaker grill, and you don't want to fill the holes/dust mesh with paint.
    AD211 likes this.
  11. Eric C
    Eric C F1 World Champ
    11,079
    St. Louis, MO
    Eric
    Just take the panel off. It's simple.
  12. Eric C
    11,079
    St. Louis, MO
    Eric
    The 488 is exactly the same. It takes 2 mins. Pull up the weather seal and loosen the 1 screw then slide the panel out.
    SoftwareDrone and up4speed like this.
  13. up4speed
    up4speed F1 Rookie
    3,697
    Long Island, NY
    Chris
    At this point, the paint made it look good enough where it didn't stand out. If it ever bothers me again, I will order the grill and install it. It's only about $50
    Eric C likes this.
  14. Eric C
    11,079
    St. Louis, MO
    Eric
    I would have just removed that panel. You'd be able to remove the grill from the back side so that you can scuff it up and repaint it. You aren't going to plug those holes up with paint unless you're rolling it on lol
    Glad you got it without removing though!
  15. up4speed
    up4speed F1 Rookie
    3,697
    Long Island, NY
    Chris
    I was responding to wolfman88 saying that he wanted to spray in place.
    But then again, even if it was removed, if there is a material/mesh glued to it, I wouldn't spray it. And once it's off, why not spend the $50 and get a brand new one.
