How to remove door panel QV | FerrariChat
Discussion in '308/328' started by blue308, Dec 18, 2007.
  1. blue308
    blue308 Rookie
    Dec 18, 2007
    7
    Every time I go to remove my door panels they seem to get hung up in the middle. Is there some kind of hidden fastener? I have unbolted the arm rest, all periphery screws etc... I can pull it on every edge and it starts to come away, problem is, it seems to be attached somewhere in the middle.
    Thank you for your assistance.
  2. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    I've been trying to remove my armrest. What i'm worried about is trying to remount the armrest without removing the door panel. How do you prevent the nuts from spinning if you don't hold the bolts from the other side when remounting the armrest?
  3. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    You did unscrew/remove the lock button?
    Also, I find it is helpful if you push the door panel in (towards the window) as you slide it upwards.
  4. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I believe there is a screw near the inside door lever. Did you remove this .
  5. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    you have to remove the trim around the door handle and unscrew, careful when moving the trim, it has two tabs which can break!
  6. Joe_CT
    Joe_CT Formula 3
    May 16, 2007
    1,782
    CT
    Joe
    I just removed both door panels as I am installing a new audio system in the car. There are two nuts and a large screw in the armrest. The armrest just pulls right off once those are off/out. I had three small perimeter screws that went through the door panel in various locations. Once you remove the screws, just lift up and out and the panel should pop right off. Good luck!
  7. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    thats how I did mine too! Pic's too come soon on how I fixed the locks
