how to remove fuel vapor hose | FerrariChat
Discussion in '348/355' started by CharlieL, Oct 18, 2013.
  1. CharlieL
    CharlieL Rookie
    Sep 23, 2004
    41
    I need to replace the hose that goes from the nipple on the driver's side of the tank to the lowest nipple on the fuel vapor accumulator (disareator in F speak) in a 1995 355. The fitting over the nipple on the tank has some sort of built in clamp that that I can't get to to release. Is there a "special tool" for getting this off so that I can replace the hose, or is there another way to get this off?
    Thanks.
    --Charlie
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    They are a bit of a pain to get off. You need to lightly pinch the clip so that the "hooks" on the bottom are spread. When they spread they aren't clipped to the bottom of the tube. The clips tend to get stuck to the o-rings, which is why hey don't come off easy. So what I have done is, pinch the clip and try and wiggle it up with a large standard/flat screwdriver. This link has a a lictureof what I'm talking about. http://www.ferrarichat.com/forum/137616317-post9.html Just be careful not to break the plastic, which is why it's a bit of a pain to get off. You can also try twisting the fitting a little bit to get it to loosen up.
    Hope that helps.
