How to remove Gasket Sealant? | FerrariChat
Discussion in '308/328' started by M.James, Aug 12, 2009.
  1. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    I am in the middle of a 30K Major, with my valve covers and cam seals 'off' the car. During the removal, I found epic amounts of Cooked-On RTV and some other dense beige sealant material used around the circular Cam Seals and the Cam Cover Gaskets. Portions of OEM gasket material around the Cam Covers are cemented to/with this material, and a plastic scraper isn't removing it. My fingernail isn't removing it. This stuff is cooked-on pretty good. What are some useful techniques to clean-off these areas without gouging the Aluminum and creating more leaks? Can anyone indicate a vendor of some SHARP scrapers made of plastic or other materials that won't marr aluminum?
  2. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #2 Pizzaman Chris, Aug 12, 2009
    I was talking to David (fastradio) and he said Popsicle sticks will be safe to use. Just get yourself a nice box of those baby's and after you are done put a little angle on them and get busy scraping. :)
  3. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,640
    Along the Verde , AZ
    Doug
    This won't help your immediate problem, but having dealt with this before, i was thinking that some sort of gurney gizmo that you can lay down flat on,and roll it up over the rear of the car, would make things infinitely easier to do something like this, especially on the front head. You could relax there at your leisure, taking your time scraping this stuff off and not killing your back.
    Probably impractical for a one car operation, but a shop taht deals with this all the time, now that may be the ticket for carb work, valve shims, etc.
    Doug
  4. Rifledriver
    37,367
    Those are comercially available.
  5. Rifledriver
    37,367
    There are aerosol gasket sealant removers available. They are messy to use. All they really are is paint remover, you could use some of that with a small brush. Silicone is broken down by conventional solvent or mineral spirits pretty well but takes a little time.
  6. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
    I used a Craftman gasket scrapper blade, I just take time and avoid hurrying....That's thing with Ferrari, it's really fragile. On my Toyota trucks, I used a brass wire wheel and battery power drill. Just make sure the RTV craps don't get into your engine heads.
  7. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Try some thinners or acetone. They won't harm the aluminium and may soften the old sealant enough to scrape it off easier.
  8. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    A shovel works pretty good for me.
    The small plastic kids kind like they use at the beach. That's what I used last time.
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Aerosol cans of carb cleaner, an assortment of stainless steel or brass bristled "toothbrushes" and a small scraper with a single-edge razor blade. A few dental picks are handy as well.
    Anything attached to a drill or die grinder should be avoided like the plague. The objective is to get the surfaces clean, not recarve Mount Rushmore.
    This is all about attention to detail. It takes time to get it right.
  10. ace_pilot
    ace_pilot Formula Junior
    Sep 6, 2007
    921
    Long Island, NY
    George
    Rifledriver, do you guys routinely put RTV that stuff on the valve covers, in addition to a new gasket, when you do a major? I have that stuff all on the edge of the valve covers after my major. I didn't think it was necessary when it's professionally done.
    end of threadjack.
    Ace
  11. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    These, coupled with patience, acetone...or carb cleaner in a can seem to do the trick, as least for the last 25 years or so.
  12. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    I've sucessfully used Permatex Gasket Remover, Item # 80646. It may take several applications, but it's the safest way to go about it. (I feel, anyway)
  13. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    #13 Frari, Aug 12, 2009
  14. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Those 'toothbrushes' would be great if they didn't come apart when using them. The bristles fall out of the plastic. You don't want to bolt it all up with anything like that floating around in your engine.
    I find the trapezium-shaped blades in a plastic holder (used for glas usually) do a great job scraping things off, but like anything hard you use, you need to use it with some feeling. The risk of damaging things if you use this correctly is minimal.
  15. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    I found some 3M scotchbrite discs that fir into a 1/4 die grinder nicely. Just be sure to get the ones that are designed for AL. These little gems are designed for removing gaskets and are very effective. When it comes time to remove wrinkle paint from the FERRARI imprint and ribs ,on the cam covers, the job will be completed in minutes with these discs. still lost
  16. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    They're called 'Topside Creepers' - have one handy, works great! A rolling, diving-board platform. One word of caution, the support structure is made of metal and needs to be foam-covered HEAVILY before using anywhere near the engine bay of the Ferrari. Already had one user create a stone-chip sized gouge in my rear quarter-panel using it without adequate fender-covers and foam padding.....
  17. RichardAguinsky
    RichardAguinsky Formula Junior
    Nov 12, 2007
    478
    Palo Alto, Californi
    Richard Aguinsky
    My Mondial had a very thin layer of light yellowish RTV with was also cooked on the valve covers. I used a painter's spatula to remove the glued on gasket material. used brake cleaner with Scotch pad and paper towels to clean the RTV. I used electrical contact cleaner for parts close to electrical wires or connectors, as I did not want to risk cracking plastic connectors wit the brake cleaner. Lots of elbow grease. I then applied a very thin coat of Toyota RTV to all the gaskets. You need to put some extra RTV where the valve cover gaskets meet the large O'Rings I also applied a thing coat of RTV around the exterior of all the seals before inserting them as a double precaution, especially on the metal distributor seals.
