How to remove heat shield on 308 | FerrariChat
Discussion in '308/328' started by Tifosi_308, Jul 24, 2006.
  1. Tifosi_308
    Tifosi_308 Rookie
    Oct 22, 2005
    17
    Dublin, CA
    Mark Saake
    I'm replacing the fabric in my '85 308qv due to some wear spots.
    I've got all of the pieces of the rear deck off except the piece directly below the window and the center "clip". From my research on threads here, these are held in with bolts from the engine compartment.
    To access these bolts, I need to remove the upper heat shield which sits between the engine compartment and the drivers area (just opposite the rear deck). There are 3 bolts that hold the heat shield on, but the bolts also hold clips that hold 2 metal lines. I can't seem to access the bolts due to the clips and lines.
    Has anyone else with a 308 removed this heat shield before, and any tricks on accessing the bolts -
    TIA
    mark
