How to Remove Oil Pressure sending Unit | FerrariChat
Discussion in '308/328' started by miketuason, Aug 18, 2015.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Does anyone knows how? I haved removed the oil filter but still no room to put my 22mm wrench in there. Thanks.
  2. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    Remove the oil filter base
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    A little heat on the wrench will let you bend to fit.
  4. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Thanks guys, I was hoping I don't have to remove the base.
  5. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,286
    Black Forest Germany
    Martin N.
    IIRC I used a shortened 22mm wrench and didn't even have to remove the oil filter. - I assume you are talking about the pressure sender and not about the pressure switch. For the latter I actually had to remove the filter. -
    It was cramped, but it worked.
    Used a cheap wrench and cut off the other end. No bending necessary.
    Where does your wrench collide?
    Best Regards
    Martin
  6. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Yes, I'm talking about the big oil pressure sender. It's collidi between the sender and the oil filter base. Also no room on the side to be it wrench unless I remove the braided oil line coming from the oil cooler. This an 84 QV
  7. dwhite
    dwhite F1 Rookie
    Remove the base, and replace the old gasket when replacing the base. It does not take long and you will not futz anything up. Let her sit overnight and wrap a towel around the base as you pull it up, as there may be a slight bit of oil still in housing.
    Obviously, take the oil line off first.
  8. John M
    John M Formula Junior
    Nov 18, 2004
    888
    Kentucky
    I think after a cold beverage or two, I managed to break old sender free with a pair of channel locks on the body of the sender. I am fairly certain I removed the filter for a little more access. And I used a stubby to tighten the new one down. May have dropped the overflow hose too. In my case, I didn't remove the filter base.
  9. TacElf
    TacElf Formula 3
    Aug 15, 2010
    1,719
    Seattle area
    Jeff
    Mike, either way you do this would you mind terribly taking pictures along the way? Love to add such pictures (with your permission, of course) next to RifleDriver's in our modern oil pressure sender kit instructions.
  10. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    No problem Jeff, glad to take some photos along the way.
  11. dinogt4guy
    dinogt4guy F1 Rookie
    Oct 31, 2004
    3,411
    Hewitt, Tx.
    Kurtis Fordice
    A crow's foot may work?
  12. Jdubbya
    Jdubbya The $10 Trillion Man
    43,734
    Hell's waiting room
    I think I used a crow's foot on mine. I remember looking for the right size and the only place I could find it was in a full set at Sears. The whole set is in my tool box and I honestly don't think I've ever used any of them for anything else.
  13. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    I used a monkey wrench to get the old one off (destroying it), then a pipe strap wrench to put the new one on. No leaks!. If you buy some gaskets taking the base off is probably much smarter but not absolutely necessary. I got one of the last original senders from allferparts.
  14. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    Mike,
    It was fairly easy to just pull the filter base and bench the adapter to remove the pressure sender. And it gives you a chance to clean things up in that area.
  15. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    I'm having this 22mm wrench grinder down thin enough to fit between the filter base and the sender unit, if this doesn't work I'll go remove the the whole base as you suggested.
  16. sltillim
    sltillim Formula 3
    1,724
    San Diego
    Also very useful for removing the dip stick base!
    I have this job as my sender just went bad. Time for a trip to get some tools :)
  17. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Any update Mike?
  18. jon s
    jon s Formula Junior
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    did an ugly thing a couple of years ago and easily removed the sender with a small pipe wrench on the body- didn't feel too guilty since it was being replaced with a new one. no serious damage to the body of the sender. sure was easier than the oil filter mount removal but crude cheers. jon s
  19. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    #19 miketuason, Aug 21, 2015
    So far this is what Ive done, I bought this 22mm wrench that has the handle thin enough to fit between the sender and the oil filter base and I had the machine shop ground down the open end to the same thicknesses as the handle then heat them up and bend it about 45deg. I'm not don't yet as I still need to bend the rest of the wrench upward as it's still too long.
    The pic below is not my engine, That's an engine that's on a stand which I'm using to make my special wrench.
  20. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Monkey wrench. Done in 1 min!
  21. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Monkey wrench might be good for removing it but putting the new one, you want to grab it on its hex.
  22. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Pipe strap wrench works perfect. No leaks and no damage to sensor
  23. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    #23 miketuason, Aug 23, 2015
  24. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    #24 miketuason, Aug 23, 2015
  25. Ehamilton
    Ehamilton F1 Rookie
    2,765
    Durham, NC; USA
    Eric Hamilton
    Crowsfoot wrenches are tools you use once every five years.... And are just so useful then that you forgive them the five years free lodging in your toolbox.
