How to remove the battery in a 348? | FerrariChat
Discussion in '348/355' started by 348kk, May 22, 2007.
  1. 348kk
    348kk Karting
    Jan 25, 2007
    106
    hi, need help again, can I get some procedures on removing the battery in a 1990 348TS, I need to put in a new battery, thanks!
  2. 348kk
    348kk Karting
    Jan 25, 2007
    106
    this is a double thread posting, can this post be deleted?
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    There's two ways to remove the battery (rear) from your 1990 348:
    1) From above. Disconnect both battery terminals. Check to see if there is a hold-down clamp on the lower front side of the battery, if so, remove the nut holding it down (not easy to reach), then take a deep breath, reach in there, grab the battery, and pull it up and out. Batteries are heavy, but I've done it on mine. You can get inexpensive tools that are designed for lifting batteries, but not really necessary.
    2) From the left rear wheel well. Disconnect both battery terminals. Jack up the left rear corner and install a jack stand under the subframe for safety. Remove the lug bolts and remove the left rear tire. With a phillips screwdriver, remove the screws (5?) holding the liner inside the wheel well. You now have a direct shot at the battery. If it has a hold-down, remove it, then pull out the battery.
    Now that I think of it, don't some 348's have a cover over the battery? Mine doesn't, so I'm not sure how that works.
  4. 348kk
    348kk Karting
    Jan 25, 2007
    106
    its seems that taking it out from above is the quickest way, I'lll attempt that first, but why go for option 2? if option 1 works? thanks
  5. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I just looked out in the garage to see if I had forgotten anything about removing the battery from above - two things:
    - Remove the left air intake tube from the air filter housing and push it out of the way.
    - Remove the cover from the left rear tail light housing, using the two thumbscrews.
    This will give you a bit more room to operate.
    Don't wear nice clothes when you do this, and wash your hands afterwards, exposure to any battery can get corrosive gunk on your hands.
  6. 348kk
    348kk Karting
    Jan 25, 2007
    106
    hi..thanks for getting back to me.. "- Remove the cover from the left rear tail light housing, using the two thumbscrews."
    how do you remove the rear tail light housing, do you have a picture of that site? thanks
  7. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    #7 Miltonian, May 22, 2007
    Just remove the tail light cover from inside the engine compartment, like-a so. Don't need to mess with the tail light itself. It gives you a little bit more room.
  8. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,617
    The Brickyard
    The Bad Guy
    THE POOL CUE JEFF! WHERE'S THE POOL CUE!?!
    :D :p
  9. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    #9 Miltonian, May 23, 2007
  10. ernie
    Nov 19, 2001
    22,617
    The Brickyard
    The Bad Guy
    HAAAAAAAAAAAHAHAHAHAAAA!!!!!!
    Oh that was good!
  11. 348kk
    348kk Karting
    Jan 25, 2007
    106
    excellent visual aids, I'll work on the first thing in the morning.. thanks
