How to remove vent window frame | FerrariChat
Discussion in '206/246' started by outofpocket, Apr 5, 2020.
  1. outofpocket
    outofpocket Formula Junior
    Dec 6, 2007
    257
    Midwest
    GD
  2. TTR
    TTR F1 Veteran
    5,198
    Riverside, CA
    Timo
    I admittedly don’t have firsthand experience with this subject on Dinos, but have done similar work on
    The item on second photo appears to be retainer channel for the vent glass (rubber) seal, not the vent glass frame and if so, to replace it, you may need to remove the drop glass first to get the vent window support structure out ...
  3. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,838
    Norfolk - UK
    Tony
    Have done this several times but a long time has passed in between!
    Seems to recall you have to remove the main glass panel which then allows you to unbolt the main upright window channel.
    Be careful not to scratch the glass, its not easy to get out
    Tony
  4. TTR
    TTR F1 Veteran
    5,198
    Riverside, CA
    Timo
    Edit:
    I apologize for my earlier post which apparently came out incomplete.
    Here’s version I likely meant to say:
  5. outofpocket
    Dec 6, 2007
    257
    Midwest
    GD
    I’m beginning to think that the next person will have to fix the bent frame!
    TTR likes this.
  6. swift53
    swift53 F1 Veteran
    6,735
    E.S.
    Alberto
    I will let you know tomorrow.
    Regards, Alberto
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    6mm slot screw on forward edge at internal face of the door, two 10mm nuts along vertical frame
    EDIT: Mine is a GTS, yours appears differently
  8. TTR
    TTR F1 Veteran
    5,198
    Riverside, CA
    Timo
    Unless you're fully confident with your own abilities/skills, don't have easy access to someone experienced and can live with the issue, this might be smartest approach
    pshoejberg likes this.
