How to rescue a Hard Drive | FerrariChat
Discussion in 'Technology' started by anunakki, Jul 10, 2013.
  1. anunakki
    anunakki Seven Time F1 World Champ Owner Rossa Subscribed
    Oct 8, 2005
    78,816
    Las Vegas Nevada
    Jerry
    I have an external Seagate HD attached to my Mac and it suddenly stopped being recognized after a year of duty.
    The problem began with beeping coming from the HD and instead of showing the HD on my desktop it showed a folder with the HD name.
    I rebooted and now the HD isnt beeping but I get nothing recognized on my computer at all.
    However, I can hear the HD spinning.
    Thoughts ?
    (I am not a tech savvy guy)
  2. wax
    wax Five Time F1 World Champ Lifetime Rossa
    Jul 20, 2003
    52,409
    SFPD
    Dirty Harry
    Hie thee to a Disc Recovery specialist. They're plentiful & affordable.
  3. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Whoa! I think that's probably a little bit of an overreaction at this stage.
    Firstly, do you have a backup of the thing anywhere? [Hopefully yes, as that takes a *lot* of pressure off! ;)]
    Do you recall the "sequence" of the beeps? [Long, short, spacing, how many etc?] It was trying to tell you something and we can probably figure it out given the details. [Model # would be helpful here.]
    Do you have another 'puter you can plug it into?
    My WAG is it's still OK (no strange noises is good) but has lost it's "index" for some reason (not the correct term, but you get the idea) - Given time, that can be rebuilt from the contents.
    Cheers,
    Ian
  4. johnb@macarbon
    johnb@macarbon Formula Junior
    Feb 24, 2004
    809
    SF Bay Area
    John Borchelt
    I'd be really careful going to a disk recovery specialist. They suck you in with a low price to 'analyze' the disk then will come back with a big number to actually get the data. Maybe its justified but be ready to spend at least $1000 with any of them. And most don't guarantee any results.
    I was quoted $2100 to recover my outlook file last fall. When I sounded hesitant, they dropped it $500. But again no guarantee of success.
    Be sure to Google any company you are thinking of using.
    Check some of the software that is out there. You'll probably have much better luck.
  5. becker
    becker Formula Junior
    Feb 20, 2001
    340
    Arlington VA
    Becker Cuéllar
    I'd assume it is a USB HD?? If so I had a similar problem after playing a bit it looked like it was a nogo, so I opened it up and the USB interface was shot was my conclusion , swapping this board is very easy and it usually is no more $40-60.
  6. Schimpf
    Schimpf Karting
    Jul 20, 2005
    137
    CO
    Schimpf
    remove it & place into another USB(3) doc would be a start. Dont know the problem though.
  7. mseals
    mseals Two Time F1 World Champ Lifetime Rossa Owner
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Have you tried a different cable between the computer and the drive?
  8. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    Also try removing the HDD from the container. You can get a USB to HDD cable and connect without a case.
  9. valter
    valter F1 Rookie Rossa Subscribed
    Jun 25, 2008
    2,872
    Nibiru
    Vlad
    Try removing it from case and putting to the other one (I can send you a simple usb case for free). If it wont help, try Disk Utility in mac checking that disk is recognized. You can then have options to check drive and repair permissions. If it wont help - professional disk recovery is the only way to do it if you have "expensive" data there. When I had a little more time on hands data recovery was my hobby lol
  10. Billy10mm
    Billy10mm Formula Junior
    Nov 11, 2003
    664
    Westchester
    Billy Ng
    Here's a good trick from someone who's spent most of his career as a system's admin - freeze it.
    There are two ways hard drives go kaput. The first is that they get dropped, a head hits a platter, head is damaged, game over. Call up one of those $1K+ data recovery places.
    The second is that a manufacturing defect has left the disk in a state where it's slowly killing it's bearing and the disk is getting slower over time. Eventually it can't spin fast enough and the head can't read data properly.
    Put the disk inside two to three ziploc bags (trying to keep moisture out of the equation) and put it in the freezer overnight. Next day, remove it from the freezer and quickly attach it to the computer. The theory is that the different metals inside the drive shrink differently and increase tolerances (loosen components) which increases the speed ... you'll have only 10 to 15 minutes before the metal in the spindle heats up again and it stops working.
    I can't tell you if the theory is true or not, but I can tell you that of the dozen or so dead hard drives I've tried to recover this way in the last 18 years, it's worked on 75% of them or so.
  11. 4REphotographer
    4REphotographer F1 Veteran
    Oct 22, 2006
    6,197
    Arlington, VA
    Chris
    Can I borrow one? One of my drives seems to have gone a month or two ago, its showing a SMART fault and wont let the computer boot without it being removed. I don't think the drive is physically dead though, I believe an old windows backup image got corrupted that is on the same HDD.
  12. Jedi
    Jedi Moderator Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,270
    Seattle Area
    Dave
    Try it on a Windows computer before you do anything extreme...
    Jedi
  13. valter
    Jun 25, 2008
    2,872
    Nibiru
    Vlad
    Sure, if Ill be on C&C on Sun, I can bring it...
  14. Innovativethinker
    Innovativethinker F1 Veteran Silver Subscribed
    Aug 8, 2009
    9,840
    So Cal
    Mark Smith
    Yup, used the freezer trick many times, but 1-2 hours worked for me (but I only used 1 zip lock bag).
  15. NbyNW
    NbyNW F1 Rookie Silver Subscribed
    Feb 3, 2007
    4,308
    South Dakota / Maryland
    Just had a backup disc on one of my iMacs go out. Can't read it on other systems either. Just got another 1T ext drive for $55 to replace it. The failed one will go under the hammer tomorrow. It was an Iomega about 2.5 yrs old. Sucks these things are disposable. But as a backup it's easy. If primary I'd try recovering on my own.
  16. SCousineau
    SCousineau Guest
    Jul 17, 2004
    3,652
    S Cousineau
    This thread is reminding me to backup my backups.
    My wife used to laugh at me until I found a couple files she's modified and saved over.
    One can never have enough backups!
