How to sharpen a drill with a bench grinder | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by luckydynes, Aug 13, 2008.
  1. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    1++ Never drill/tap any aluminum without coolant or some sort of spray lube/oil etc. Nothing besides concrete can ruin a tap or drill like dry aluminum can. Goes through it like a hot knife through butter with coolant. Lots of good cheap products like Spray Tab or any other cutting/drilling lube you can buy in a spray can for $4 from McMaster, ENCO(www.useenco.com) or Grainger. At least use WD40 if you have nothing better.
  2. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    one of these days we're gonna play a round against a pro . . . I just haven't had the time to mount the thing on a golf cart and work out the transformer/amplifier req's to run the servo off the 48V available from the golf cart . . it's almost as fun as playing with cars :).
  3. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Well this one's probably not 101 . .. if I expect my recently purchased bbq'd 308 motor to run again I'm gonna need to make some new cam journal caps among other things for it . .. I'll have to make some tooling to line bore it all again . .. not as exciting as Mark's V12 conversion but might be entertaining seeing why I'm not getting other projects done doing "fun" things like this . .. for some reason I just love taking completely abondoned trashed f'd up "things" and making them work again . . . and when they work better than they ever did oh what a feeling :).
    cheers all.
    BTW the other thing about aluminum is CRANK UP THE RPM and definitely use coolant . .. small drills you almost can't get enough rpm to be "textbook" with standard knee mills and engine lathes . .. aluminum cuts like wood 'round 'ere. :) . .. I have a 2" carbide insert face mill I run at 3000 rpm if I'm in a hurry ... chips are like bullets coming off it.
  4. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    I want one of those even thoug I have a couple of mills . .. man can never have too many machines, or too much shop space . . and there's the saying, junk expands to meet available space.
    cheers
