How to store your 296 for winter? | FerrariChat
Discussion in '296' started by pninja005, May 9, 2024.
  1. pninja005
    pninja005 Formula Junior
    Nov 10, 2010
    604
    Europe
    Since there is no trickle charger anymore what is the best way to store your 296 for winter?
    My car is set for production in November which means it will most probably only hit the road in April next year.
  2. MikeS
    MikeS Karting
    Nov 21, 2003
    164
    Connecticut
    Mike S
    You still plug it in as the charger deals with the high voltage battery pack and the 12 volt battery which is now AGM, not lithium.
    jm2, Dino_Argento and pninja005 like this.
  3. CinciOptics
    CinciOptics Karting
    Nov 10, 2022
    153
    James B
    Some suggest fill it up completely with gas and dont start it again until winter breaks to avoid moisture in the lines.
    Others say start it every week to two weeks regardless.
    Everyone agrees that tire savers are best to avoid creating a bad spot on the tires as the car will sit on concrete without moving for a period of time.
    pninja005 likes this.
  4. pninja005
    Nov 10, 2010
    604
    Europe
    Thanks a lot! Question was oriented towards the battery charger.
    I always inflate tires (+1 bar); put on on foam and don't start the car during the period it sits.
    Seems to work fine this way.
  5. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,329
    Iain
    You will be able to download the MyFerrari app and it will give access to the status of the car and show the state of charge of both the low and high voltage batteries. It dials into the car at least twice a day and will ping you an alert if there is a battery issue. It shows if the charger is connected or not but if the GPS signal drops out when it is communicating with the car it seems to think the charger is disconnected. It does not give you a lot of advanced warning though if it detects an issue so if it does send an alert I'd advise checking the car out in person asap if possible.
    I was in a similar situation to you in terms of my GTS arriving in time for the bad weather season and it has sat quite happily on the charger throughout the winter.
  6. D11
    D11 Karting
    Sep 26, 2010
    215
    I kept mine plugged in through the winter and drove occasionally. No issues.
    Remember not to store the key near the car just like with the SF90’s as they are constantly transmitting data if kept to close to one another. Unplug every so often for a few hours even if your not driving it and then plug it back in I was also advised.
  7. Caeruleus11
    Caeruleus11 F1 World Champ
    11,604
    You can also over inflate the tires. You will see the max psi rating on the tire sidewall- they are usually something around 50psi max. I would fill it to a few psi below the max rating- 45 or so.
    I think the 296 also has a “long parking mode” which does something for the battery- you could look more into that to see if thats a good idea for longer term parking.
  8. JesseRohr
    JesseRohr Formula Junior
    256
    Austin Texas
    Jesse Rohr
    Reading through this I am so very thankful I live in a climate I can drive year round.
    I am impressed by those who have the willpower to store their cars for extended amounts of time. I think I would not be able to and would likely just brave the snow with proper tires.
    KL runner likes this.
  9. pninja005
    Nov 10, 2010
    604
    Europe
    Winter is coming :(
    Can you put the car cover while the car is plugged in?
    I store my cars in a garage and I normally don't go there for months. Plan is to let it sit for 6 months.
    jm2 likes this.
  10. gzachary
    gzachary Formula Junior
    Jan 10, 2011
    831
    California
    How do you stop the tires from deforming? I start and move any car of mine at least every 6-8 weeks. Assuming you are letting the car’s weight rest through the tires on to the surface below, it is likely that you will have some tire deformation if you don’t move the tires at 6 months.
  11. KL runner
    KL runner Formula Junior
    Jul 25, 2023
    730
    Not in US
    Or put the car on stands , there are four points indicated in the manual
    gzachary likes this.
  12. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,168
    michigan
    john
  13. doomsnoopy
    doomsnoopy Rookie
    Oct 13, 2024
    1
    michal pilat
    Hello all , in living in Romania so the winter is not so bad not lot of snow in last years but anyway the plan is to drive it
    296 gts so maybe o dont open the roof but i my plan is to have the car as a daily
    Dino_Argento likes this.
  14. pninja005
    Nov 10, 2010
    604
    Europe
    Thanks a lot for the picture! I didn't know there is a cut out for the charger :)
    jm2 likes this.
  15. pninja005
    Nov 10, 2010
    604
    Europe
    I just inflate the tires with 1 bar. Have this been done for years with cars even sitting 9 months. I never had any deformation or issue.
    gzachary and LVP488 like this.
  16. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,168
    michigan
    john
    There isn’t. Wife made one for me.
  17. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,872
    France
    Low profile tires are typically very rigid, on the 488 I did not see any deformation even after a few months (when I was living abroad). For whatever reason, the 296 has higher profiles though (35 front and rear vs 35 front / 30 rear on the 488 and F8), and is also heavier, so maybe that's something to look at.
    jm2 likes this.
  18. Lagunae92
    Lagunae92 F1 Rookie
    2,825
    SoCal
    what's winter? 65 degrees?
    jm2 likes this.
  19. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    939
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    I cover my car with the red cover and a waterproof cover all over the charging cord .
    My car is kept under my carport --unfortunately I do not have an indoor garage space.
    Car seems happy and stays clean when I need to use it.
  20. pninja005
    Nov 10, 2010
    604
    Europe
    Covers fits over charger; all good :)
    kussetimii, bamaman and jm2 like this.
