How to test for frozen 206 Dino motor | FerrariChat
Discussion in 'Technical Q&A' started by V12 Ciao, Jul 31, 2023.
  1. V12 Ciao
    V12 Ciao Rookie
    May 2, 2021
    8
    Chris Schmalbruch
    Planning to inspect a 206 Dino and would like to determine whether the motor turns freely. Can someone provide guidance, please. Will a socket wrench suffice? Socket size?
  2. wmuno
    wmuno Formula Junior
    522
    Wilmette, Illinois
    Bill Muno
    38 mm or 1-1/2” socket for the harmonic balancer bolt. See references for the Fiat Spider. They both used the same 2 liter motor.
  3. V12 Ciao
    V12 Ciao Rookie
    May 2, 2021
    8
    Chris Schmalbruch
    Many thanks.
  4. hessank
    hessank Formula 3
    1,953
    Canada, Florida
    Fred
    There was a Wheeler Dealer episode where Ed advised that before trying to turn a suspected seized engine to remove the spark plugs and completely soak the walls of the cylinders with WD40 or similar. Let it soak a bit then turn clockwise
    Cameron Henlin and Edward 96GTS like this.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    I have never seen a 38mm socket ...
  6. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,231
    Georgia
    Wade Williams
    I believe it is 36mm. That is the socket I use on Ferrari crank bolts.
    2NA and Island Guy like this.
  7. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,182
    Atlanta
    Tom Spiro
    is it being noted at seized up? why not just put it in gear - take the oil cap off and rock the car, watch for the camshaft to turn? it's being reported as seized ... then try to turn by hand?
    Ferrari Tech likes this.
  8. Rifledriver
    37,288
    Why bother? If if it needs that to turn the motor is junk and needs an overhaul.
    tomberlin, Ferrari Tech and willrace like this.
  9. hessank
    hessank Formula 3
    1,953
    Canada, Florida
    Fred
    #10 hessank, Aug 3, 2023
    I agree Brian but Chris asked for help and I provided what I heard. Also if by chance it did not rotate(truly seized) then the answer would have been to move on to another engine. I know absolutely nothing about engine rebuilding cause I'm still trying to get past my own ordeals when I pick up a wrench.
    'If it ain't broke, fix it till it is'
    Fred
    V12 Ciao likes this.
  10. V12 Ciao
    V12 Ciao Rookie
    May 2, 2021
    8
    Chris Schmalbruch
    Agreed. Good way to go. Actually, better than the wrench on the harmonic balancer nut is to put it in third gear and push. Light car, easy to turn over motor…..if not frozen.
  11. V12 Ciao
    V12 Ciao Rookie
    May 2, 2021
    8
    Chris Schmalbruch
    Yep, easy solution. Thanks.
  12. tbakowsky
    Sep 18, 2002
    20,038
    The Cold North
    Tom
    Put a battery in it..and turn the key..
    tomberlin likes this.
  13. spirot
    Dec 12, 2005
    15,182
    Atlanta
    Tom Spiro
    Help is what I do.
