How to test spark coil? (308) | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Quasimotor, Jul 31, 2006.
  1. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Growing up in TX, we used to go drinking in an odd corner of somebody's large pasture. Occasionally we'd have a newbie along, & after a few we'd go 'visit the bushes'. Those in the know knew where to aim, yes, there was a fence in the bushes...
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    I'm having trouble following.
    I believe you have said that you've established that BOTH coils are cutting out, just not both at the same time. This was done by:
    Replacing BACK coil early in this thread.
    a) post #23: Pulling the FRONT coil's yellow wire & car kept running on the BACK coil -> FRONT coil isn't firing.
    b) post #24: Replaced FRONT coil w/former rear coil. Still ended up running on 1 bank. Pulling the FRONT coil's yellow wire & car died -> BACK coil isn't firing.
    IMHO, you've established:
    - It's heat sensitive, only occurrs after a run.
    - It's probably not a coil problem.
    - Problem can affect either bank.
    -> Look for things common to both banks such as:
    . ECU grounding
    . ECU power (fuse or fuse block? wiring?)
    . motor speed (Flywheel tooth) sensor?
    I suspect that the backfiring & loud exhaust are either due to raw fuel being dumped into the exhaust when a bank starts cutting out, or else you have an unrelated lean mixture problem.
    Umm, let me think some more about what the lambda system will do when it detects raw gas from the bank that's cut out. It may try to correct the problem by lowering the K-Jet distributor's output pressure, leaving the bank that's still got ignition running lean.
  3. Quasimotor
    Quasimotor Formula Junior
    Jan 4, 2004
    352
    Yonkers, NY
    George Avgerakis
    Wow, Verrell, you are quite the analist. It feels good to know there is still someone sane reading this thread!
    Would you consider what the symptoms would be if there was lack of spark on either coil for just microseconds - creating the impression that I was firing on both banks, but that in actuality, I was running - lean?
    Would this also cause extra noise from the exhaust - and a kind of slapping sound like one piston wasn't getting spark?
    Quasi
  4. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    yup! If you want to prove that, disconnect the O2 sensor. It's a single wire plug tucked up on a frame rail underneath the air filter box and to the right of the fuel distributor. The wire is probably green, and the connector is probably white.
  5. Quasimotor
    Jan 4, 2004
    352
    Yonkers, NY
    George Avgerakis
    Please be a bit more specific. What is supposed to happen when I disconnect the O2 sensor? Do this with the engine running? If the sensore is bad, could this be the cause of my problems?
    Q
  6. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    verell's comment about lambda.
    if you are getting unburned fuel into the exhaust, the O2 sensor will think the engine is running rich. The injection ecu will compensate by changing the frequency valve signal to lean out the mixture, which will cause the bank that is still running to go lean.
    by unplugging the O2 sensor, the injection ecu will no longer try and fiddle with the mixture, so the running bank will revert to getting whatever the base fuel mixture is as set by the adjustment screw in the fuel distributor.
    All that disconnecting the O2 sensor should do is get rid of any lean running symptoms, which are just a byproduct of the misfiring bank. The real problem still appears to be electrical in the ignition system.
    'course, this whole rathole is only relevant if you car has the lambda system. You have a frequency valve happily buzzing on top of the fuel distributor?
  7. Quasimotor
    Jan 4, 2004
    352
    Yonkers, NY
    George Avgerakis
    What's the frequency valve look like. For that matter, what's the fuel distributor look like - is that the unit on the rear right that has the individual fuel tubes running out of it - kind of like an old octopus furnace?
    Is the Lambda a standard Ferrari unit or an add-on? If I don't have the Lambda, is there still an 02 sensor in my car that could be causing the mixture to go lean? That would explain some of this.
    Q
  8. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    #33 wolftalk, Aug 15, 2006
    right on the fuel distributor. The frequency valve would be sitting kinda on top of it on the left side. see pic below from a 328 that sorta shows what it looks like. It's the same on the 308.
    it's standard for us spec cars. I don't know if your euro has it, since it's primarily emissions related. Second pic is the wiring from the o2 sensor to the car. If you don't have the frequency valve, you won't have any use for an o2 sensor.
    The fuel injection ecu watches the o2 sensor output and varies the signal to the frequency valve. The frequency valve adjusts a control fuel pressure in the distribution head, which changes the amount of fuel squirted by the injectors.
    The injection ecu can lean or richen the mixture in response to what the o2 sensor is reporting. If you dump unburned fuel into the exhaust, the o2 sensor output will go to about 1V, and the ecu will try and compensate by leaning the mixture as much as it can via the frequency valve. There's a limit to what the frequency valve can do, so while it may be pegged as lean as the fv can make it, the car will probably still run.
    You don't want to just unplug the fv, as that would also peg the mixture as lean as the fv can go. If you unplug the o2 sensor, though, the injection ecu will default the fv to the middle of it's operating range
  9. Quasimotor
    Jan 4, 2004
    352
    Yonkers, NY
    George Avgerakis
    Wolftalk! Thanks! I'll look at this tonight.
    In the meantime, I followed everyone's advice and began with the fuse panel, where everything looked okay. Then I checked the continuity of the lines going to and from the coils. What I found immediately, was a massive ground at the diag plug - several pins shorting to body. I removed each of the wires from the coils, one by one and found the ground on the last one - the 12 volt, yellow supply line from the ignition switch!
    Traced this to the fuse panel, where the plug was on the "hot" side of the panel. The fused side had a line to the radio, which had been taken out (by me) and a hot lead dangling behind the dashboard! Aha!
    I removed the dangling line. I moved the yellow 12 v. supply to the coils to the fused side of the panel - putting it on the first bus (where the plans say it should go - shared with something else (keep this in mind). Then I reconnected all the coil leads and remounted the terminals. Then, without testing the engine (cause I was sure I had the problem licked), I installed the newly acquired, original 84 Becker radio. It ran fine - until the last minute when I was kind of pushing wire harness around to stuff the radio into the hole. The radio just quit.
    I was in a rush to take a friend out - so I started the engine - fine and went for a ride. The problem came back, same as ever - missing on the rear bank and then not even firing.
    Needless to say I was frustrated and gave it a few days to fizzle out. Now I will go back to the radio and see if I left something undone there. But a quick check shows 12 v. coming to both coils and no short on the 12 line. I guess, after the radio, I will check the continuity of the negative wires on the rear coil.
    If I read 12V on the line from the digiplex during run, should it visibly jitter on a normal $!5 Radio Shack voltmeter, or is the frequency too high to "see?"
    Continued thanks to all who remain with this frustrating thread!
    Quasi
  10. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    something doesn't sound right....your car has the little yellow jumper wire between the two coils, right? If so, there is one yellow wire coming from the fuse box to coil A, then the yellow jumper goes from coil A to coil B, and then another yellow wire goes from coil B to the diag connector. If there was a problem on the yellow wire from the fuse box to the coil, both coils would lose the +12V and the car would instantly die. It's also not really possible for the yellow wire to be tied directly to ground....the fuse would blow. If for some reason the wiring was misconnected so there was no fuse, the wire would become a toaster element until something melted/burned up enough to break the connection.
    how are you checking continuity? If you just stick an ohmeter between the +12V and gnd, you'll probably see very little resistance. You aren't supposed to measure powered circuits with an ohmeter.
    the wire from the digiplex to the coil is grounding the coil terminal through a transistor inside the digiplex. The 12V you see on that wire is not coming from the digiplex, it's coming from the yellow wire through the coil whenever the digiplex is not grounding the wire. In other words, when the digiplex is not grounding the wire to fire the coil, you will measure 12V on both sides of the coil.
    in any case, it doesn't sound like the problem is the coils. As verell said, I'd focus on the digiplexes and the plugs between the digiplexes and the coils/sensors.
    have you swapped the digiplexes yet? All the have to do is swap the plugs between them.
    Have you checked the plugs between the digiplexes and the coils/sensors yet?
    if you connect a voltmeter to a non-yellow coil wire, make sure the meter is set for measuring AC voltage, and you should measure around 2.8-3.5V when the car is idling...at least, those are the numbers for a 328. I'm assuming the 308 is about the same, but possibly not since the 328 ecu is talking to an electronic module on the coils instead of grounding the coils directly. In any case, it should be lots less than 12V.
    you can also measure the sensors. The tdc sensors should be >0.2V, and the tach sensor should be >2.0V.
    if your diag connector diagram is accurate, you can measure all those things via diag connector pins. Hopefully the problem sticks around long enough to make the measurements.
  11. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I love point ignitions and carburators.
  12. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    WolfTalk- have you or anyone else here made a diagram Labeling the Diag pins with what voltages, wavefoms etc to be expected at each pin ?
    (seems like it would be a quick way to narrow down problems at one convienient location)
  13. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    FWIW, my Lucas coil lasted 30 years. Then starting the car got progressively harder until it died. I bought a new Lucas Sport coil which is the gold one, and it's internally ballasted. Believe it or not, it's the only thing I'm aware of that Lucas makes that is superior quality. That thing has super high output and is especially good on old carb cars to help prevent fouling.
    Ken
  14. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    #39 wolftalk, Aug 18, 2006
    if the diagram in the US '84 owners manual is correct, then this is what you should see:
    - 12V between pins 7 and 9 when key is in run position
    - around 3V AC between pins 1 and 9 at idle
    - around 3V AC between pins 2 and 9 at idle
    - >0.2V AC between pins 3 and 4 at idle, around 700 ohms between pins when not running
    - >0.2V AC between pins 5 and 6 at idle, around 700 ohms between pins when not running
    since pin 9 is ground, you can tap gnd off the frame instead. Having gnd in the connector is only useful if you have a plug to stick into the socket.
    Also, I lied about the tach sensor. It's not connected to the diag socket on the 308.
    If you have a scope, then you'd be looking at pulses on the pins 1, 2, 3/4 and 5/6 above instead of AC voltages.
    problem is how the pins are numbered. It appears that ferrari numbered the plug on the diagram in "ignition system components" in the manual, looking into the pins in the plug. On the schematic, the numbering would be for the pins in the socket, so the numbering is mirrored.
    since we just care about the socket in the car, it looks like the pins are numbered like in the diagram below. Someone should confirm, though.
  15. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    My Dino was running well with a slightly bit more backfiring on deceleration so I checked all the high tension/spark plug wires. I'm using the MSD 6200 unit and MSD coil and upon pulling/pushing the coil wire it came out along with the screw in post adapter which was coated in black liquid (oil?). I cleaned and replaced, car still ran well.
    What is the failure mode of a coil? (dies, limps or...?)
    If all is running well, how do you know when to replace the coil?
    Thank you
  16. Quasimotor
    Jan 4, 2004
    352
    Yonkers, NY
    George Avgerakis
    Based on the graphic input above - I have the following to report.
    Clue #1: Every time I go out to start the car, fresh after about 24 hours sitting, it starts and runs fine - with a good spark out of the rear coil. After it warms up and I take it for a ride - about 5 minutes - the tach starts bobbing, the engine starts running lean, backfiring and then minutes later I lose the rear bank spark.
    Clue #2: While idling on the front spark coil only, and testing the diag tips, I accidentally shorted pins 2 and 3 with the test lead - this created an immediate jump in RPMs to the normal 1100 - as if the rear bank kicked to life. If my finger jumped the pins (higher resistance than metal test lead?), I got an immediate backfire. Weird?
    I can't seem to get accurate readings from my cheap, Radio Shack analogue volt-ohmeter, so I'm going out today to get a new digital one.
    I haven't had a chance to swap the digiplex's nor take apart the distributor cap to test the central spark wire. These have been suggested.
    At present it is clear this problem starts when the car warms up.
    Quaz
  17. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    The car got harder to sart: more cranking before it would catch. First it would take a second, then two or three, then even longer. When it got to the point it was hit or miss that it would start (and I was discharging the battery a ton every time), I started replacing the 30 year old stuff: rotor, distributor cap, wires....nothing helped. I finally replaced the coil and wow...cranked instantaneously. Just like a real car! Now one caveat: the old coil was ballasted and the new one is internally ballasted, so I naturally bypassed the ballast resistor. It never occurred to me that the coil might have been fine and the resistor was no good! LOL But It wasn't expensive and the things do die. If your car starts and runs fine, I wouldn't replace it just for fun. It's not like a timing belt that you want to prempt a failure on.
    Oh, and the new coil made for less fouling too; much stronger spark.
    Ken
  18. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    wolftalk - Thanks ! Excellent and very clear-well labeled. This should speed up troubleshooting. I do have a scope and would love to take readings periodically to look for changes(potential problems). Now I can.
    Great job !!!
  19. Quasimotor
    Jan 4, 2004
    352
    Yonkers, NY
    George Avgerakis
    Okay - here is the results of my test according to Wolftalk's extensive suggestions.
    1. Took off digiplex plugs and tested connectors with following results:
    824 Ohms between 1 & 5 and 2 & 3 on both connectors
    2. All other connectors as indicated by Wolftalk.
    3. I switched digiplex leads to start off - went for short ride - problem returned (engine idling at 5-600 with backfiring).
    4. Came back to garage, opened rear hood to pull 12v. from front coil - engine died, indicating the rear coil was not firing - so the problem is exactly the same. So it's not the digiplexes thank God.
    5. Restarted engine - still hot enough to run badly, but after a few minutes, it returned to 1100 RPMs. I tried closing the rear hood - and after a minute or two, the revs dropped to 5-600. I opened the hood and again, after a few minutes, revs go back to 1100. After awhile, I can no longer repeat this effect and the revs stay at 5-600, probably because whatever is getting hot, stays that way.
    6. Now I disconnect the digiplex connectors and get the following readings readings of 384 ohms on pins 1 & 5 and 2 & 3 on both connectors!
    I still get 12V. between 8 and 9 - even when running badly, indicating (I think) that the short power wire between pins 8 on the front and back digiplex is good (my symptoms could be replicated by cutting this line, right?)
    7. While I have the digiplex connectors diconnected, I tested Diag points with following results:
    5 & 6 = 374
    4 & 3 = 379
    All other pins correct according to the pin diagram posted above.
    8. Strange thing, however, is that even after 10 minutes of not running car, the readings remain the same, but after reconnecting the digiplexes, the car runs at 1100. Of course, if I leave the hood down, it will eventually drop again.
    The car is still warm as I write this, but my guess is that after awhile the ohms test will return to the 800's. So - the runs bad with the ohms in the 300's but it will also run good with the ohms in the 300's.
    BTW, there is no Lambda on my system - the photos shown above do not have the extra unit on the side of the fuel distributor. My schematics also do not indicate an O2 sensor. Are we sure one exists on the '84 Euro 308? Also, on which fuses do the digiplexes get their power?
    Can anyone make sense of the above?
    Extreme respect and thanks to anyone who continues to support this thread - I hope it is proving helpful to others.
    Quasimotor
  20. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    wow!
    I can't give you an answer on the main question, which is whether the sensors drop in resistance as they get hotter. I'd expect the opposite, actually. To find out, you've got a couple options.
    1] repeat the performance until you get the low resistance, then disconnect and measure sensor resistance at the two pin plug that is near a sensor to see if you get the same value
    2] remove a sensor and heat it with a hairdryer or something while measuring the resistance
    since both TDC sensors are doing the same thing, and you've got a bouncing tach and the rpms are dropping (even if you lose a bank, the idle shouldn't change that much if the remaining bank was firing ok), I'm thinking something is wrong at the main plug between the ecu's/diag connector and the sensors.
    The schematic shows a 6 pin plug someplace, but I don't remember where it is. I'd guess it's somewhere around the top of the driver side rear shock. Should be easy to follow the sensor wire bundle back to it.
    If you haven't already, find that connector, unplug it, and make sure nobody sprayed the pins with something nasty. If there's any evidence of stuff on the pins, hose it down with an electrical cleaner or denatured alcohol. Avoid any cleaner that has a lubricant or things like wd-40.
    While you've got the plug apart, you can also measure the sensor resistances from there. I dunno what the plug physically looks like, but the US schematic says that sensors are connected to it like:
    pins 3&6 - tach sensor
    pins 2&5 - tdc sensor for 1-4 bank
    pins 1&4 - tdc sensor for 5-8 bank
    as a hint, the tdc sensor wires only have a single wire on the pins on both sides of the plug, and it looks like the wire on pin 1 is yellow, the wire on pin 4 is black.
    another hint that you'd have conductivity where there shouldn't be any is if you get a non-infinite resistance between the sensors. You'll need to unplug the ecu's for this, and then measure between unrelated pins. For example, between pin 1's on both ecu connectors.
    on the 328, the sensor plug is a little round thing that has no "walls" between some of the pins. If someone left a heat sensitive conductive residue inside the connector, some of the pins could be partially shorted together.
    The behavior you saw when shorting pins in the diag connector I'd ignore. The sensors are generating pulses on the wires, and pin 2 on the diag connector is also getting pulses from the ecu. Shorting pin 2 and 3 would cause the 5-8 bank coil firing pulse to be fed into the 1-4 bank TDC sensor input. What happens I guess depends on the timing...pretty unsafe thing to happen.
  21. Quasimotor
    Jan 4, 2004
    352
    Yonkers, NY
    George Avgerakis
    Good work, Wolfie! Thanks alot!
    I don't think the problem is both heat related and localized to the sensors, which are really under the car and not subject to the effect of having the rear deck open or closed.
    The six-pin connector might be the cause, if it was in the engine compartment - I'll look for it.
    What if the resistance issue (that is, the TDC sensors) is not related? (even at low (300) resistance, the problenm goes away). What else could be a cause of a dead rear bank? How about the spark wire itself or something more localized to the rear bank under the hood?
    RPMs naturally drop to half if half the engine is idling. There is the added resistance of 4 pistons not firing. I have always seen drops in RPM when cutting out single or multiple pistons.
    Anyone else want to chime in.
  22. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    if the low resistance in the sensors/sensor wires is not normal, the signals the
    sensors are generating could be degraded to the point that the ecu can't detect them or they are so noisy they don't make sense.
    in this situation, everything depends on how the ecu interpretes the inputs, e.g. if it's trying to sanity check, average, filter noise, etc. For example, if you start the car when the sensors signals are poor, the ecu may be able to sync to them until some errant spike confuses the ecu, and it either shuts down or is firing the coil at the wrong time.
    hmmm....that's not my experience. When I've seen 3x8's with a bank that is out, they still run and idle ok. Losing a cylinder or a bank affects the rpms slightly, and you can hear the difference, but it's not like the you lose 125 rpm for each cylinder that is lost.
    if it's not the sensors, I think you only have a couple things left to look at. You can measure the AC voltages as mentioned earlier if you have a better meter (any cheap digital meter should be fine), or use a timing light/spark tester on the plug/coils wires to see if there's an irregular firing pattern.
    If still no answer, you'll probably need to find someone with a scope so you can take a look at the signals. Unless they work on fcars, you'll have to tell them what the pins in the diag connector are for, and all they need to do is display the waveforms on them. Maybe we can bribe spiderseeker to hook up his scope and post some pics of the primary and secondary waveforms.
    the thing I'm wondering is if you aren't really losing a bank, but you are misfiring randomly across both banks. Disconnecting a coil stalls the car because you've lost too many cylinders. If this is happening, then the engine could stumble to a stop after disconnecting a coil because there's still a couple cylinders in the other bank firing. A timing light or 1+ of those cheap inline spark testers (like attached to the purple plug wire in the pic previously in this thread) can be used to see if the spark is really missing.
    also, you'll have to check the spark plugs for fouling eventually.
  23. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    I don't believe any of the Euro QVs had lambda. Steven Rochelin's is an '85 and I'm almost certain it doesn't. JWise's has an '84 & I know it & my '82 don't have lambda.
    I think only the US & possibly CH or JA QVs had Lambda.
    My experience matches Wolftalk's, I've lost a bank & idle speed didn't drop by half, just a hundred rpm or so. Engine felt sluggish. from the way it felt, I figured I'd lost a cylinder or 2, was surprised when it was a whole bank.
  24. Quasimotor
    Jan 4, 2004
    352
    Yonkers, NY
    George Avgerakis
    Thanks everyone. This morning I tried opening the distributor cap. All looked more or less nornal. I polished off the rotor contacts and trimmed a half inch off the central wire from the coil - no change in the problem.
    I think it's time for a professional to look this puppy over and I'm sending it down to Brian Vignale in Short Hills NJ. I bet he finds it in an hour. Will report my findings as soon as I know for everyone's edification. Unless any of you come up with something new before tomorrow noon!
    Best wishes
    Q
  25. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    did you find the 6 pin connector? look directly under the shelf-like flat area next to and in front of the coolant tank
