How to transfer files more than 4 Gb in size?
Discussion in 'Technology' started by Remy Zero, Aug 3, 2013.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. Remy Zero
    Remy Zero Two Time F1 World Champ
    Apr 26, 2005
    21,240
    KL, Malaysia
    MC Cool Breeze
    Hi guys,
    Is there a 3rd party software to download so that I can transfer files more than 4 Gb in size into my pen drive?
    Thanks!
    P/s: I'm using an iMac OS X
  2. toggie
    toggie F1 World Champ
    Rossa Subscribed Owner
    Nov 30, 2003
    15,856
    Virginia
    Toggie (Ron)
    Not sure if this helps you or not but I like using DropBox.com as a web tool to share large files across computers.
    DropBox is free for the first 2 GB of total space used.
    You can earn free additional space or purchase whatever you need.
    Works great across multiple computers and can even synchronize shared folders in the background.
    If you use it as a transfer-only tool for typical files, then the 2 GB space limit is easy to stay under.
    You just delete shared folders defined within DropBox that have already been transferred to your other PCs before adding new shared folders.
    Since you're trying to transfer larger files over 4 GB in size, you'd have to sign up and pay for a larger DropBox space to do that.
    A plan for 100 GB of space is $8.25 per month.
    https://www.dropbox.com/plans
  3. valter
    valter Formula 3
    2,055
    Northern VA
    Vlad
    Reformat pen drive as MacOS Extended in disk utility instead of default FAT. Problem solved. This is limitation of FAT filesystem and has nothing to do with any software. NTFS for windows will do the same.
  4. Remy Zero
    Apr 26, 2005
    21,240
    KL, Malaysia
    MC Cool Breeze
    Thanks guys! Cheers!
  5. Asian1118
    Asian1118 F1 Rookie
    Mar 23, 2005
    3,834
    Shelby twp
    James
    Check out sharefile.
  6. Innovativethinker
    Innovativethinker Formula 3
    2,333
    Bear Creek, Ca.
    Mark Jones
    Google drive also works well
  7. Tired of seeing this ad? Upgrade now
  8. becker
    becker Formula Junior
    Feb 20, 2001
    291
    Arlington VA
    Becker Cuéllar
    Formatting to NTFS or MaC HFS should take care of that. If u have files in the drive that u need to back before a reformat, u can use split there are a few versions ... split the bigger file into 2G chunks and glue 'em back in the target drive.
  9. Remy Zero
    Apr 26, 2005
    21,240
    KL, Malaysia
    MC Cool Breeze
    I should be trying this out sometime later today. Hope it works.
  10. EnzymaticRacer
    EnzymaticRacer F1 Rookie
    3,946
    Sunnyvale, CA
    Robert W
    Don't bother with "splitting" the files. That just making this process more difficult than it needs to be.
    Simply move all data off of the thumb drive, then perform a format to the new filesystem, then move all files plus the new 4+Gig files back onto it.
  11. Remy Zero
    Apr 26, 2005
    21,240
    KL, Malaysia
    MC Cool Breeze
    Right. It did work halfway. I've managed to transfer more than 4 gb of files into my pen drive, however in the process, I dont know if I did it right, but now my pen drive can only be read on macs, and no more pcs...
  12. Gran Drewismo
    Gran Drewismo F1 Rookie
    Jan 24, 2005
    3,373
    Idaho
    Andrew
    Did you format it to Mac HFS?
  13. Remy Zero
    Apr 26, 2005
    21,240
    KL, Malaysia
    MC Cool Breeze
    I'm not too sure. My cousin did it for me actually. Now it can only read on Macs.
  14. Tired of seeing this ad? Upgrade now
