"Howling" noise | Page 3 | FerrariChat
"Howling" noise
Discussion in '308/328' started by mike996, Apr 22, 2021.
  1. Rifledriver
    37,350
    #51 Rifledriver, May 24, 2021
    Pulse air injection system. 328 is famous for it and the noise is not made by all cars and only happens in certain narrow temp and climate conditions. Pulse air shuts of over a certain RPM or throttle position, don't recall which. Also goes off when coolant temp starts to rise. It draws its air from the right fender vent and generally is loudest on right side in and around the air induction plumbing. Sounds mechanical but is a result air pulsation of the reed valves.
    You have described it pretty perfectly. It has a temperature below which it does not operate. It has a temperature above which it does not operate. It has an RPM or throttle position above which it does not operate.
    https://algarferrari.com/store/parts/6-8-cylinder/328-group/328-gtb-gts/table-10
    RodC328gts likes this.
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,929
    Mike 996
    Thanks RifleD!!! I had no idea that the pulse air system could make the noise but it makes perfect sense. Same thing that makes clarinets, saxophones, and all the reed instruments work! :)
    Rifledriver likes this.
  3. BNSC100
    BNSC100 Karting
    May 28, 2009
    127
    SC
    Michael
    This has been VERY informative. A very limited search online seems to show that in some cases reed values could be tested / replaced on some cars.
    Does replacing anything improve this or is it just something that happens and you live with it...? Can it be "fixed."
    Sometimes the diaphragm in the regulator of my gas grill hums, but it just is what it is.... Part of life.. Is that what we have here?
    RifleD: You are a true gift...
  4. RodC328gts
    RodC328gts Formula Junior
    Aug 17, 2021
    458
    Mexico
    Rod C
    A/C Compressor belt or bearings ?
  5. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
    On rare occasions my '87 will make the noise but a blip of the throttle ends it. And, indeed, it only happens in cooler weather. I've owned the vehicle for nearly 34 years and have never used synthetic oil in it.
    308 milano likes this.
  6. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,929
    Mike 996
    No. RifleD explained the cause in post 51.
  7. Lawrence Coppari
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
    Next time you hear it after starting, jump out, open the engine cover, and place your hands on the check valves. You might be able to feel it.
  8. tom wortham
    tom wortham Karting
    Apr 14, 2018
    64
    Plano, Texas
    Inowownone
    Great Thread!
    My 87 - 328 makes the same noise during cold weather - cold starts(Dallas, TX). Once the oil temp gage moves (oil warms a little) the sound stops. This usually is 2-3 minutes engine running and a 10th of a mile drive distance. I just live with. Glad to hear it's nothing major.
    Cheers Mike996!
  9. tom wortham
    tom wortham Karting
    Apr 14, 2018
    64
    Plano, Texas
    Inowownone
    I forgot to mention... I have a Tubi exhaust. I thought it it had to be warmed up a little before the whistling stopped. LOL
    Temp greater than 75 degrees, no whistle.
