430 - Huge oil pump failure | FerrariChat
430 Huge oil pump failure
Discussion in '360/430' started by Mario Andretti, Apr 18, 2023.
  1. Mario Andretti
    Mario Andretti Formula 3
    1,777
    Boston
    Hi all,
    Horrible first track day for me.. after 2 laps, I lost control of the car, and spun out for no reason... Lucky I did not hit anything. I am not a newbie and I have done this track many times on my M3.... I was surprised as hell...
    Anyway, I go into the pits, we look around the car, and all looked ok... Marshall said " cold day, maybe cold tires, just take it easy"
    Next lap, same place, rear slides out a bit, but I catch it. All of a sudden , I get black flagged, and go straight into the pits. Ton of oil under the car.... Reason I spun out is that on the right hander, off camber uphill my tire was nicely greased in engine oil.
    I never lost oil pressure or see any lights on the dash... Have not started her since.. Got it towed home by AAA. I see the oil seeping from here; see pic.
    I know this car had the water/oil pump rebuilt by some shop in CA twice... in 2018, at 15k miles (now at 19K). But it was due to water leak.
    I thought it could leak water from here, what do you guys think, how come it's leaking oil out of that hole?
    Anyway, I will probably buy a new one and replace it... Hopefully engine is ok.
    Any feedback is welcome obviously...
  2. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    380
    NC
    There’s a seal on either side of the weep hole on the shaft. One side is oil. The other side is coolant.
  3. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,021
    NE FL
    Ken
    Following.
    I don't think a "seep" would have caused any issues at all, your car would have had to be gushing oil.
    Any other signs?
  4. Mario Andretti
    1,777
    Boston
    No .. this is after I got home and ALL of the oil got out on my pan and on flatbed... it was gushing at pressure at high rpm
  5. Mario Andretti
    1,777
    Boston
    So this is after 3 hours of seeping oil
  6. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,021
    NE FL
    Ken
    I gotcha, so almost like a seal broke and just shot all the oil out over a few laps?
  7. Mario Andretti
    1,777
    Boston
    Yes it seems so.. barely got 2 laps then in the 3rd going slow...
  8. Mario Andretti
    1,777
    Boston
    #8 Mario Andretti, Apr 18, 2023
    so... it seems that the later pumps (which do not include the mounting bracket) are cheaper by 200 pounds than earlier pumps.
    https://www.ricambiamerica.com/217628-f430-complete-water-oil-pump.html
    So what happens if I install a later pump - 217628 , without the mounting bracket, is that a deal breaker (my car is a 2005 ass. number 216016, so if I go for the correct part it would be 213223) ?
    The main thing is that the old style is not in stock, but the new one is.
    Thanks for any input.
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    #9 mike32, Apr 19, 2023
    If the oil is coming out the tell tail, it will have collected on the bottom tray and when you go around the corner it has gone on the tyre. An oil leak is unusual as its normally the waterside which is no problem .
    Looking at the pic, that tell tail is right next to the water pump, so the mechanical seal might have failed. Easy enough to rebuild with a repair kit if you have a lift to get to it
  10. Mario Andretti
    1,777
    Boston
    That's exactly what happened Mike... I would like a new pump instead of recon.. should the later model work (without bracket) ?
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Not sure, i think different frame numbers have different pt no pump. Jgivoo on here has the correct repair kit with the mechanical seals etc- there is a u tube on rebuilding it and dead simple. I looked at doing mine myself but you might get it off with the car jacked up- you need 2 pairs of hands and a lift to refit it.
    Just check the oil is coming from the tell tail and not running down the back of the pump from the o rings on the block
    flash32 likes this.
  12. Mario Andretti
    1,777
    Boston
    I am looking at the rebuild kit; and I am 99% positive that this seal has failed in my case; this is the oil seal on the shaft of the pump Circled in red) . But the pump had bad history, it has been "rebuilt' twice by shops in CA before I bought the car (it's in the maintenance history)
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Is that one of the china made kits ? If that pump has been rebuilt twice then something else going on with the drive to the pump from the engine
  14. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    or it was rebuilt twice by the same idiot
  15. Mario Andretti
    1,777
    Boston
    Yes, 257 on Ebay :) .. Either way, I bought a new pump from eurospares, 1600 USD shipped with all needed seals. Just got out under the car, dropped the oil and coolant... there was still a lot of oil in the engine so I think I am good on that side.. But ; because the pump has been removed at least twice, I have to order all new screws.. the heads are smashed badly , darn.
  16. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Have you seen the pics of the plastic sheets to help refit the pump ?
  17. Mario Andretti
    1,777
    Boston
    Yes; I will see when I take it down how hard it is without them, if not, I will order them also. I am not sure yet if they are really needed...
  18. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Go to the local stationary store and get a few plastic folders, the thin stiff plastic. Then make plywood handles and bolt each side of the plastic. Other way is 3 drops of superglue @120 deg on the o ring to hold in situ
    Mario Andretti and flash32 like this.
  19. Mario Andretti
    1,777
    Boston
    Hold on, the superglue will harden up and could make it not seal properly ? Or do you think it will dissolve in oil be a non issue?
  20. Scottslaw
    Scottslaw Formula Junior
    Man, I'm sorry to hear this. I didn't have a failure, but had some coolant weeping, so given the 65k hard miles on my car I figured I'd just replace the whole unit and not try to rebuild it. I'm glad I did because the new pump gears meshed more easily and I could tell they would create more pressure than my old unit, so I like the peace of mind knowing that my oil is circulating at the max pressure possible. Since my car is an 08 I used the later pump part number. With that said, I THINK the only difference is a bracket for the early cars (and 6 speed cars). But I don't know for sure. It was a fiddly job, mostly due to tight access to many of the bolts, but not technically difficult (provided you have a lift and a way to support the engine while the motor mount on the right side is off). Also, I had to grind/trim a few wrenches and sockets (did I mention some of the spaces are tight?).
    I did not need the special tool or any superglue. I used "o-ring" lube that I got at home depot. It is silicone based and the brand is Danco. Found it in the faucet repair isle. The WSM mentions a "grease" for the orings and I even tried to source it by calling the dealer, but they said "the techs just have a tub of stuff they use...no part number or retail option). However, this "grease" serves no lubrication function and I didn't care if it would hold up to heat. The only purpose is to keep the orings in place (which are on all sides of the pump) while installing so they don't fall out of place (and so you are not tempted to commit suicide trying to keep them all in place while contorting the pump into position). I had zero issues using this grease because it is super sticky and no orings shifted or moved at all, even the ones oriented upside down. And after 500 miles, I took the undertray off and there are no leaks.
    About that radial seal. I replaced mine even though there were zero signs of seepage or damage. But it was not fun getting it out. You do NOT want to score the bore it sits in or you will get leaks, which excludes using any type of pry tool or pick against the edges of the seal. So what I did was drill two small opposing holes in the recess of the installed seal, screw in two coarse thread drywall screws, and gently work the seal out using pliers on the screw heads. Took a bit of finesse but it came out fine. Before you remove the old seal, mark with a sharpie the insertion depth because as I recall it was not obvious how deep to insert the new seal. to install the new seal I just used an appropriate sized socket to apply even pressure around the circumference of the seal and then gently tapped with a rubber mallet to the appropriately marked depth. I actually regretted replacing this seal because of the stress and consternation it caused me trying to figure out how to safely extract it, and because it showed no signs of wear, but now I'm very glad that I did after hearing your story. Shoot me a pm and I'll give you my number and I can share alot more detail. I'm going to do a diy write up with pics but was just being lazy. Maybe I should try to do it now! There are a lot of little hints I can share that will hopefully save you some time!
  21. Mario Andretti
    1,777
    Boston
    Many thanks! I will PM you; just in case I hit a roadblock when I install it... I ordered a new one (with new bolts) , considering the history on mine, being removed twice for re-seal; I gather something must be wrong there. If not, I'll just rebuild it and keep it for a spare.
  22. Mario Andretti
    1,777
    Boston
    Is this what you used
    https://www.homedepot.com/p/DANCO-0-5-oz-Silicone-Faucet-Grease-88693/203193536
  23. Scottslaw
  24. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    I clicked on this thread expecting catastrophic engine failure. I'm glad that you only have a minor issue.
  25. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,945
    Central NJ
    Dominick
    KY jelly works well
