Hum from rear wheels on speed | FerrariChat
Discussion in 'Technical Q&A' started by Emirateshills575, Feb 11, 2023.
  1. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Sinusoidal hum from the rear wheels, at a speed of 95-120 km / h, if i am driving faster - the sound disappears. What could it be? Rubber, bearing, cardan shaft, differential?
    Gtc4lusso 4WD
  2. tazandjan
    39,160
    Wheel/hub bearing.
  3. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    Could be a bearing. However, if it's more sinusoidal in nature, I would first start by looking at your brake pads/rotor. If the rotor it out of plane even .003-.005" and/or the pads aren't retracting fully, sometimes that can cause noises as you are describing. Also, does it sound like it's coming from both wheels or just one side of the car. If both, it might be related to the differential or something related to the drive train.
    If you lightly apply the brakes while traveling that speed, does it alter the sound any?
    You might also try coasting in neutral and see - while traveling that speed - if the sound goes away when you take the engine torque out of the equation momentarily, etc.
    Ray
  4. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    I tried neutral, but sound not gone, I can't tell if the sound is coming from one wheel or two, so I ordered new hub now, then will check
  5. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    That's one approach.
    Ray
