360 - HVAC "clunk" | FerrariChat
360 HVAC "clunk"
Discussion in '360/430' started by mfennell70, May 23, 2020.
  1. mfennell70
    mfennell70 Formula Junior
    Nov 3, 2003
    586
    Middletown, NJ
    When I start my car and turn on the climate control, there's a 'clunk' as something in the HVAC unit opens or closes. I could have sworn I saw a reference to a fix once but my FerrariChat/Google search fu is failing me.
    I'm pulling my dash to replace the defrost vents with aluminum so I'll have access.
    Thanks for any pointers!
  2. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,229
    Santa Clarita, CA
    I think that clunk is the magnetic clutch, for the a/c compressor, engaging.
  3. RedNeck
    RedNeck F1 World Champ
    10,016
    The CSA
    Me
    I have that too. Never gave it a second thought until now, ha. It comes from behind the dash, not the back, if it's the same one I am thinking of. I think it's normal and has never affected the operation of the HVAC.
  4. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    Pretty sure it’s an Hvac flap changing positions. Mine does too
    E60 M5 likes this.
  5. LP360
    LP360 Karting
    Jun 12, 2016
    169
    Lee
    Mine does this also. When I first got my 360 I thought it snapped with the noise I heard but it works 100% so got use to it. :D
    billy.gif Formula Junior
    Mar 9, 2017
    259
    Finland
    Ye, same here. Its quite loud "clunk" tbh. Kind of plastic flap opening sound.
  7. sierra055
    sierra055 Formula Junior
    354
    Melbourne, AU
    Marshall
    There are a series of motors called flapper motors in the heater box behind the centre console. Often on start-up, the recirculate motor opens and closes a flap which is at the base of the heater box and is pretty audible.
    The part circled in yellow is the recirculate flap and the flapper motor is in red. If it runs for more than a few seconds, make sure the plastic rod that connects to the flap hasn't broken which can cause the motor to run excessively.
  8. mfennell70
    Nov 3, 2003
    586
    Middletown, NJ
    So, a case of "they all do that" then? I was so damn sure I had heard of a 'fix'. It's funny, I've owned the car for nearly 10 years but can't recall if it's always made the noise or not.
    Thanks guys.
