430 - HVAC Control Repair? | FerrariChat
430 HVAC Control Repair?
Discussion in '360/430' started by BlacktopRacing, Apr 4, 2025.
  1. BlacktopRacing
    BlacktopRacing Formula 3
    1,002
    Pittsburgh
    Dale
    Has anybody ever had their HVAC control panel go bad? Mine is working sporadically. For example, the only way I can get heat if if the A/C is turned on. After a while, it starts switching where to direct the air on it's own (no, it's no on auto either). if so, did you just replace it with a new one, refurbished one, or did you get yours refurbished? I am interested in getting mine refurbished since I already went through the trouble of de-stickying it. I'm hoping there is somewhere in the US that checks/tests them and can repair them. Thanks.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,919
    Central NJ
    Dominick
    Check the sensor for interior temp and light sensor
    Sometimes a bad sensor can cause those types of issues
  3. BlacktopRacing
    1,002
    Pittsburgh
    Dale
    Thanks, but I'm not sure what those are. Also, what does light have to do with HVAC?
  4. Qavion
    Qavion F1 World Champ
    14,279
    Ian Riddell
    Do we have any resistance vs temperature charts for any of these sensors, Dominick?
    @BlacktopRacing It's rarely the panel that fails. It's mostly just switches and resistors inside. More likely other HVAC components. Have these faults accumulated over time, one by one, or did everything break at once?
    For the heat issue, are there any ticking noises suggesting TGK (hot water) valve failure?
  5. Qavion
    14,279
    Ian Riddell
    The sensor on top of the dash detects radiant heat from the sun. It is kind of a light detector.
    flash32 likes this.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,919
    Central NJ
    Dominick
    I would look at the data parameters in a good diag tool and see if temperature appears ok
    Light sensors on dash are used to direct airflow in HVAC systems ...I can't recall if the 430 has it or not ..usually the red bulb on dash
  7. Qavion
    14,279
    Ian Riddell
    There's a little circular grille between the steering column and the centre console. Air is sucked through the grille with a tiny fan, which flows over an interior temperature sensor. Maybe check airflow with one ply of toilet paper (if the fan is strong enough to move that).
    There's also the sensor under the driver's mirror.
    As Flash says, it's probably easier to use a scanner to look for faults. I assume the Ferrari SD tool shows temperatures for these sensors?
  8. BlacktopRacing
    1,002
    Pittsburgh
    Dale
    Thanks, all:
    A) There is some sort of little round dome in the top/center of the dash - not sure what it is, if it's related, or how to test it.
    B) There is no ticking sound that would suggest the TGK, although I did have it a couple of years back and was able to reset it by pulling the fuse (had to do it on two separate occasions).
    c) I thought the little circular grill was a speaker for instrumentation, key, and other warning sounds, LOL. I'll check it for airflow later. Would the car need to be running, or just in ignition 2 setting?
    I really wish there was somebody around who can properly diagnose it. I did have one ASE certified mechanic state rather confidently it's the HVAC module.
    Qavion likes this.
  9. Qavion
    14,279
    Ian Riddell
    #9 Qavion, Apr 4, 2025
    The little suction fan should only need the key on. The fan itself is independent of the AC system. If the toilet paper trick doesn't work, I'm not sure if can hear the fan running above all the other noises (if you put your ear close to it)???
    The fan is required because the sensor may be sitting in warm stagnant air (under the dash). If it's warm there, then the aircon heat is not likely to be commanded on.
  10. Qavion
    14,279
    Ian Riddell
    Sounds like the one.
    Not sure how to test it either. It may produce a variable resistance, but I don't have any resistance values (for given temperatures). The connector is probably hard to get to, also, so you'd have to do checks at the HVAC ECU connector which I recall is also buried in the dash somewhere.
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,919
    Central NJ
    Dominick
    The best to start would be looking at all the parameters in the live data stream and see if anything pops out .. also use the activation menu to see if you can control the HVAC etc
    If I was near you I would stop by and see what we can do
    But the diag tool data stream and activation tests are your best friend
    Qavion likes this.
  12. GogglesPisano
    GogglesPisano F1 Rookie
    3,206
    East Bay, California
    Joe
    I have sporadic function on mine as well from time to time. I'm chalking it up to a sticky blend door or mode door for now as I can usually force a change by toggling either the recirc button or moving the temp from one extreme to the other with the fan on full. I'll eventually hear a blend door or similar flip open in the dash somewhere. There's a lot of insulating foam on these parts that gets sticky after a while. I need to do a dash out eventually, so I won't know for sure until then. In the meantime, I'm making it work with my secret code of button pushes :D I did have one scenario where the floor was blowing cold and the main vents were blowing hot. That was a weird one. I also have an extra switch panel but I'm too lazy to swap it out and check.
    Qavion likes this.
  13. Qavion
    14,279
    Ian Riddell
    Actually, it's mounted on the left side of the evaporator (a few inches behind the interior temp sensor).
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,919
    Central NJ
    Dominick
    After you read codes ..disconnect battery and see if behavior changes ..that may give more insight if ECU issue
  15. BlacktopRacing
    1,002
    Pittsburgh
    Dale
    Unfortunately, I have no idea what you're instructing me to try. Zero.
    So you're saying the actual "brains" of the HVAC system are NOT in the panel that contains the dials, but rather this monstrosity under the center of the dash? :(
    I don't think my next "special" car will be a Ferrari because there is absolutely nobody around who knows anything about them where I live (Pittsburgh, PA).
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,919
    Central NJ
    Dominick
    You can PM me and we can get in the phone ..
  17. Qavion
    14,279
    Ian Riddell
    Then it’s important that you know how to at least use a quality OBD2 reader and a multimeter (voltmeter/ohmmeter) if you have no local experts for issues like this. Also, you’ll need lots of spare time, patience, basic tools and (still) a big wallet if you’re going to DIY it. You’ll also have to be a contortionist to get into those tight spots.
    If you think Pittsburgh is bad, try living in Australia. You have to send some things overseas to have them fixed, not just interstate :D
    Intermittent issues are the worst. Even the experts have to shotgun defects from time to time, i.e. keep replacing components until you find the faulty one.
    I bought a second hand TGK (hot water) valve last year just to see what was inside. Looked quite robust. Not sure what fails inside them. Plastic cogs? Potentiometer contacts? This example seemed to be a little sticky at the endstops (on the bench), but I don’t see how you could lubricate it if the parts are always submerged in coolant. Maybe coolant/antifreeze is a natural lubricant.
    On earlier cars like the F355, the HVAC ECU (brains) used to suffer from blown “driver chips”. These are the power chips (transistors) which drive components like valves and flapper doors. If these external components are aging or getting sticky, sometimes they blow the chips (due to the higher current required to move these external devices). The chips are easy enough to replace by your average stereo/TV repair guy (if you show them what to change), but if you don’t replace the external devices, you can blow up the new driver chips. The 430 HVAC ECU will have similar driver chips, perhaps with a little better ability to handle more stress, but everything has its limits.
  18. BlacktopRacing
    1,002
    Pittsburgh
    Dale
    I don't have a diagnostics computer, so I'm skeptical about what we can do over the phone
    What is this "spare time" thing you talk about? I have none, let alone "lots" of it. I also have no patience. I don't mind turning wrenches and do it frequently, but I'm not about to become a full time technician. I prefer to pay those who are. Im more intrigued by this HVAC ECU thing, because i never knew there was such a thing. I was told the brains were in the module with the dials and buttons.
  19. Qavion
    14,279
    Ian Riddell
    After the Ferrari 348, the brains and controller got a divorce.
    BlacktopRacing likes this.
  20. Qavion
    14,279
    Ian Riddell
    I haven't seen the inside of the F430 HVAC ECU, but this is what it looks like on a F355
    The 6 smaller chips control the flaps/vents/valves. The functions of each chip are known, but the F430 has more flaps and things. The configuration will be different and therefore unknown. You could trace specific pins on the (bright yellow) connector to individual chips, but that sounds like hard work. FAI or the ECU Doctors may be able to help you with the ECU (if required).
  21. BlacktopRacing
    1,002
    Pittsburgh
    Dale
    Seems like you know a lot about this sort of stuff. I'm not going to attempt any electronic repairs. It's not my thing, but I'll glady pay somebody to do it. Related question, how does one remove the HVAC ECU, and/or that monstrosity of an assembly it is part of?
  22. Qavion
    14,279
    Ian Riddell
    #22 Qavion, Apr 5, 2025
    Still trying to figure that out. Looking at photos of the ECU, it looks like it's mounted on 4 posts with access to the screws on the other side of the firewall? (or should I say "frunkwall")
    What a totally stupid design.
    For reference, the connectors are under the dash (right side of photo)
    Experts?
  23. BlacktopRacing
    1,002
    Pittsburgh
    Dale
    How does that come... separately or as an assembly only?
  24. Qavion
    14,279
    Ian Riddell
    #24 Qavion, Apr 6, 2025
    Definitely separately, but it's still not cheap.... if you can find one. Looks like it's NLA.
    P/N 204068
    Second hand one here:
    https://www.ebay.co.uk/itm/285125624513
  25. BlacktopRacing
    1,002
    Pittsburgh
    Dale
    Thanks. How sure are you that it's the e? CU and not the assembly containing the buttons and dials? Recall the original post, where I mentioned I only seem to get heat when the air conditioning is turned on. Also don't get airflow to the floor when it acts up. Finally It seems to have a mind of its own, changing ventilation settings, even when not set to auto.
