348 - HVAC Control Restoration. | FerrariChat
348 HVAC Control Restoration.
Discussion in '348/355' started by ChoonHound, Jun 5, 2023.
  1. ChoonHound
    ChoonHound Formula 3
    2,215
    Saint Michaels, MD
    Lucas
    Hello everybody. What’s the latest thinking on HVAC panel restoration; I think I need it? My shop disassembled the panel and fixed some broken solders, and that seemed to work for a bit, but now it’s on the fritz again.
    It can’t possibly be rocket science, it’s essentially a bunch oh off and on buttons… right? I found a thread from
    2014 with the email address of a man who fixed a panel for another member.
    Any leads appreciated!
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    ChoonHound likes this.
  3. ChoonHound
    2,215
    Saint Michaels, MD
    Lucas
    It won’t stay on. It seems vibration and/or perhaps heat related. Upon start up it works, but after driving it loses power. Sometimes I’m able to poke it and get it to come back momentarily.
  4. bjwhite
    bjwhite F1 Rookie
    4,806
    Seattle, WA
    Brian White
    Hidden fuse I bet. :)
  5. ChoonHound
    2,215
    Saint Michaels, MD
    Lucas
    I’ve heard about this… is the fuse loose in its holder?
  6. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    A number of people on here reported problems with the rear electrical connector not fitting very tight especially on early cars. I think they moved the position of the plug on later models to take the strain off the plug. Might want to check that out.
    Qavion likes this.
  7. ChoonHound
    2,215
    Saint Michaels, MD
    Lucas
    Mines a 93 build, but it does sound like that could be it. I will check!
  8. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Commonly it is disassembled and the pins that stack together when reassembling are thoroughly cleaned and that often fixes this issue. Also the female pins may be stretched too wide and not firmly connecting.
    If it comes back on if you poke it, its not the hidden fuse as that's is in the front boot but it should be replaced with a glass audio fuse. You can see it in the sticky section.
    https://www.ferrarichat.com/forum/threads/hvac-flap-motor-and-hiden-fuse.590569/
  9. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    I am keen to follow your progress as my 348 has the same gremlins.................
  10. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
