Hvac Weak air flow | FerrariChat
Hvac Weak air flow
Discussion in '360/430' started by raywong, Apr 15, 2020.
  1. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    Hi guys,
    Do you ever close the AC recirculation flaps? I lose most of the air flow when the flap is closed. I can only get decent air flow when recirculation flap is open, temperature set to Low, fan speed set to auto. Do I ever clean the blower or the evaporators?
  2. 24000rpm
    24000rpm F1 Rookie
    hm...... blend door problem? I've never had that problem before for all these years, nor did I hear any
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,955
    Isle of man- uk
    360 or 430 ?
  4. 24000rpm
    24000rpm F1 Rookie
    he has a 360. But 430 and 360's hvac are pretty much identical
  5. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    yes a 360. I don’t think the flaps are working properly. these are 20 year old plastic gears and linkages. I will ask the mechanic to take apart the air distribution box to take a look.
  6. 24000rpm
    24000rpm F1 Rookie
    how much is he asking for removing dash and the unit? if not for the close border thing, i'd go and do that for you for half of HK price.... LOL
  7. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    I was hoping it doesn’t involve removing the dash...
  8. RichardCH
    RichardCH F1 Rookie
    4,661
    they pull out, you need to make a diy tool there is a thread somewhere
  9. 24000rpm
    24000rpm F1 Rookie
    don't have to remove the dash to pull out the HVAC unit?
  10. RichardCH
    RichardCH F1 Rookie
    4,661
    apols though this was the cylindrical dash air vents
