Hydraulic fluid Power Top F355 | FerrariChat
Discussion in '348/355' started by jwestmd, Feb 24, 2007.
  1. jwestmd
    jwestmd Rookie
    Feb 8, 2007
    3
    Does anyone know where to add fluid to the hydaulic pump for the convertible top. It should be easy but I can not see filler hole.
  2. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    #2 Dcup, Feb 24, 2007
    Finally,I got the rite procedure of bleeding the top hydraulic system from the "official" workshop manual.
    I think I have to share this to everyone,especially for 355 spider owners...
    A-Solinoid valve
    B-Compensation valve
    1-Pressure bleed screw
    2-Main piston
    3-Secondary piston
    4-compensation valve fastening
    5-Main piston bleed
    6-electrical pump
    7-compensation curcuit opening screw
    FILLING AND BLEEDING PROCEDURE
    1)Disconnect the right and left primary cylinders from the hood frame at the fork ends at the two pivot bolts(#2)
    2)Check the oil level in the tank with the primary cylinders fully retracted.Top up if necessary,without exceeding the "Max" level.
    3)Using the emergency push buttons put the primary cylinders through 5 complete cycles to bleed the pump curcuit.Whlist the cylinders are moving the pump noise should be a constant pitch.Any changes in pitch indicates air in the pump curcuit.
    4)End the cycles with the cylinders fully retracted.Then check the oil level again!
    5)Open the manual valve located on the pump body,opposite the ECU.(#1)
    6)Hold the left primary cylinder with the fork against the bulkhead panel with the piston fully compressed.The bleed nipple should be at the top!
    7)Invert the right primary cylinder so that the fork is at the top.
    8)Fit the bleed tube to the nipple of the left cylinder and put the lower end in a suitable to contain the displaces fluid.
    9)Open the bleed plug
    10)Pull out the piston of the right cylindeer by hand WITH the bleed nipple open on the left cylinder.This will purge any air from the cylinders themselves and the high pressure pipes connecting them.
    11)Close the bleed nipple(6Nm)to prevent any air being drawn back into system,the top up the reservoir to restore the level.
    12)Close the manual valve(#1)
    13)Open the manual valve located at the bottom of the compensation valve(#7)
    14)Using the emergency push button,operated the pump to fully extend the piston of the left primary cylinder.Both pistons should now be fully extended.
    15)Close the manual valve located at the bottom of the compensation valve(#7)
    16)Using the emergency push button,put the primary cylinders through 5 complete cycles.
    17)At the end of this stage the pistons of both cylinders should be synchronized and there should be no change of tone.Any changes of tones indicates air in the system and the entire procedure must be repeated from step 4 until all the air has been purged.
    18)At this stage cylinders must be fully retracted and the oil level in the reserveoir must be between "MIN - MAX".
    DO NOT OVERFILL!!
    19)Reconnect both primary cylinders the hood mechanism.
    20)Test opening and closing.
  3. jwestmd
    jwestmd Rookie
    Feb 8, 2007
    3
    Thanks so much
    I have a lot of experience with hydraulics in marine applications but was unsure of this application. Your info is exactly what I was looking for.
    Thanks again.!!!!
  4. f355spider
    f355spider F1 World Champ
    18,044
    If it hasn't dropped much below the "min" mark, just top it up and drive.
  5. leorosa
    leorosa Karting
    Feb 26, 2008
    170
    Puerto Rico
    Leo
    I know this thread have some time.. but with this way the secondary cylinders bleed too?
  6. leorosa
    leorosa Karting
    Feb 26, 2008
    170
    Puerto Rico
    Leo
    #7 leorosa, Dec 18, 2010
  7. leorosa
    leorosa Karting
    Feb 26, 2008
    170
    Puerto Rico
    Leo
  8. jdsin818
    jdsin818 Rookie
    Oct 31, 2011
    1
    After trying a couple of other methods posted on the web, I got nowhere!
    Your method was the only one I saw that mentioned inverting the passenger side piston..This made all the difference in the world.
    Thank you!
    Jeff (Hero Motorsports, Van Nuys CA.)
  9. gobuffs2002
    gobuffs2002 Karting
    Aug 7, 2010
    242
    Colorado
    #10 gobuffs2002, Jul 7, 2012
    I followed the bleeding procedure above and still have two problems when I try to get the top up:
    1) When the main RAM on the passenger side retracts it misses the fork to lift the right side of the top up. Pressure placed on the fork moves it back in place so the passenger RAM can engage the fork. I looked to see if there were any adjustments but could not see any. I also did not see any bent frame members. The top on the passengers side is a little lower that the drivers side. Pushing the fork in so it will meet the Main RAM will lift the top up about one half of an inch.
    2) the small RAMS do not engage at all to get the top to move forward even after the passenger fork is pushed back and engaged on the main RAM.
    Any help would really be appreciated.
    thanks everyone.
  10. WATSON
    23,679
    WI
    I have seen this on a couple of cars now (mine included).
    The conclusion I have come to is that either the rams are leaking internally and do not
    close quickly or completely enough. Or the pump assembly is worn and is not creating
    adequate pressure to pull the forks into position quickly or completely enough.
    I have not found any adjustment option that allows for the correction of the issue so my
    assumption is that the issue is internal to the hydraulic operation. Anyone able to find where these might be adjusted??
    Are the small rams triggered to operate after the main rams are fully retracted?
    As a group, we will need address the replacement options for the 355 rams that control
    the top....as I understand it they are NLA or extremely expensive.
  11. gobuffs2002
    gobuffs2002 Karting
    Aug 7, 2010
    242
    Colorado
    Well, I got most of the problems resolved. I again followed the bleeding procedure
    from FloridaF355. I made sure to do each step exactly as written. This resulted in the secondary RAMS getting totally filled and no movement was possible indicating they both had filled with hydraulic fluid.
    Thank you FloridaF355 for the precise procedure.
    One very important thing I found out is that the secondary RAMS only engage when using the console switch. They will NOT move with the emergency switch.
    The secondary RAM movement resulted in the top actually extending out an additional 1/4 of an inch. The fabric was snug and very tight. I used the three side bolts of the frame base to move back the roof frame to allow for the roof to properly lock down on the windshield frame.
    The only problem I have not been able to resolve is the passenger side fork being further out from the pivot bolt resulting in the top not being able to fully close by itself.
    I guess that is the next challenge! The roof frame does not appear bent in any way.
    Any ideas would be appreciated.
    I'll post detail pictures when this is all over.
  12. Shauny3779
    Shauny3779 Rookie
    Jun 7, 2014
    12
    Newbury uk
    Shaun
    My hood seems to go up too far at the back! What determines the the height, is it the micro switch, or is it programmed?
  13. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    Although, I'm looking carefully at two, this thread makes me wonder if I really want a Spider.
  14. Dino Chang
    Dino Chang Guest
    Dec 29, 2012
    772
    I would say go for the GTS or GTB mate, and leave the spiders to the men :D
  15. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Ya!! It is a Ferrari now. WHat fun would it be if you didn't have something like this to tinker with. Mine still works as designed, fingers crossed.
  16. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    Although I have seen Michael's mechanical fix, this top looks like it was designed by my famous uncle, Dr. Ruben Goldberg, PhD, the designer - - on a day when he was really "messed up".
  17. f355spider
    18,044
    +1. Well said! ;)
  18. Ari Paul
    Ari Paul Rookie
    Sep 18, 2018
    34
    Ari Paul
    Hi! How do you bleed the SECONDARY cylinders??!!
    I have done the bleed procedure twice and my primary cylinders work perfectly, but my secondary cyilenders never work and they move easliy in and out like they are empty (no fluid).
    Thanks for the help!!
  19. Qavion
    Qavion F1 World Champ
    14,269
    Ian Riddell
    Ari, just be aware that the secondary cylinders have no pressure if the roof is not being moved (and also when the roof is going down). Pressure is only applied when the roof is going up and the primary actuators have reached their "up" (fully retracted) limits.
    The pressure switching is done by the "F1" valve behind the driver's head (Left Hand Drive cars) when the S2 and S4 internal microswitches in the primary actuators have been activated. S2 and S4 are activated when the primary actuator pistons are fully retracted.
    Here's the hydraulic diagram:
    Roo fHydraulic Diagram
    If you have a problem pressurising the secondary pistons, you may have a problem with the "F1" valve solenoid or one of your primary piston internal switches. Were the pistons working before the bleed?
    The F1 valve and solenoid is shown in in DCup's image (Inset "A")
    There should be 12 volts at the solenoid when the roof is being closed (and the primary actuators are fully retracted). I can't remember if there is a quick disconnect plug at the solenoid (for checking voltage)
    WATSON likes this.
  20. Ari Paul
    Ari Paul Rookie
    Sep 18, 2018
    34
    Ari Paul
    Qavion,
    Thank you!! That response was extremely helpful! And prompt! Got it, so, for the secondary rams, it's only a temporary pressure assist, almost like a squirt of pressure, to push the top of the roof to unfold and close on the windshield, but otherwise they are depressurized. Correct? Well well...
    I can't answer your question about whether the secondary rams were working before the bleed because I don't remember using the top for more than two years and I only used it once before then when i first got the car!
    But... look what I found! (See pictures attached). It looks like for the passenger side secondary cylinder, the ram is bent!! The driver side secondary ram is fine however (perfectly straight), it's just the passenger side that has been damaged. I do remember that when I tried to use the top when I first got the car, the passenger side was drooping down (I think passenger side main ram was weak or had air).
    Does this need to be replaced? Is it bad enough to cause problems? And do you have a better idea why this might have happened?
    Best to you.
  21. Qavion
    14,269
    Ian Riddell
    #22 Qavion, May 18, 2020
    Not sure. There is an internal microswitch on the left hand secondary actuator, but not on the right. The microswitch in the left hand actuator deactivates the pump motor at full extension (fully closed).
    On the surface, your bent actuator doesn't look too bad. Is it jamming at full retraction? It shouldn't because there is only hand pressure pushing back on the ram (but full hydraulic pressure in extension). If it's not jamming or leaking, it's probably ok, but why it bent, I don't know... unless someone was jumping up and down on the roof :p
    Basically correct. The squirt is controlled by the F1 valve and the fully extended microswitch in the left hand secondary actuator. If the roof controller doesn't see the fully extended microswitch activate, the pump will be commanded to run as long as you have your finger on the roof close switch. If the switch is permanently showing fully extended, then your pump motor may not provide enough pressure to complete roof closure.
    Can you compare the left and right secondary actuator rams to see if the resistance to hand pressure is the same?
    Ari Paul likes this.
  22. Ari Paul
    Ari Paul Rookie
    Sep 18, 2018
    34
    Ari Paul
    Excellent information. Thanks again! I have to keep my fingers crossed that nothing is wrong with my left hand secondary actuator microswitch because the left hand secondary cylinder is the only thing I haven't sent in to be rebuilt! ...maybe I should bite the bullet and just have that rebuilt as well...
    OK, let's assume, for the sake of argument, that I have had all 4 cylinders/rams as well as the solenoid rebuilt. They are rebuilt and tested 100% by a totally reliable rebuild company, but, I still have the same problem with my secondary rams not activating. In that case, what then???
  23. Qavion
    14,269
    Ian Riddell
    #24 Qavion, May 19, 2020
    I haven't checked, but there must be an electrical connector on the left hand secondary cylinder. Just put an ohmmeter on the two pins (or sockets) and see if you have an open circuit with the cylinder in all positions except fully extended. Note that I'm going by the old Ferrari wiring diagrams. The switch may be closed circuit in all positions except fully extended. Just make sure it changes state at full extension.
    There should be two microswitches in each main actuator also which change state, but these will be harder to check unless the system is depressurised. The electrical connectors on these will have 3 pins, so you need to know which pin does what. Go by wire colour on the wiring harness going to the connector. Do you have my wiring diagram?
    I don't know where you are located. USA? Will you be sending the cylinders to these guys?
    https://www.tophydraulics.com/82-ferrari-355-f355-spider
    I would do as much electrical diagnostic work before sending the cylinders away. There could be other electrical/mechanical faults. e.g. with a fault with your F1 solenoid valve.
    https://www.tophydraulics.com/ferrari-355-f355-spider/331-rebuild-service-for-ferrari-solenoid-valve-block-168888.html
    When the main cylinders reach full extension, there should be power sent to the solenoid. I would try to put a voltmeter on the solenoid electrical connector (shown in the picture above) and see if 12 (?) volts appears. If you have a 12 volt power supply (or spare battery), apply the power to the solenoid plug and see if you can hear the valve change position. Check the resistance of the valve coil to make sure it's not open circuit. I assume the valve has a spring loaded plunger like the F1 gearbox actuators. If you don't hear any noises when you apply power, I would take pressure off the system and carefully remove the solenoid valve* and check the plunger for movement. It's possible that the plunger has gummed up with lack of use.
    *to avoid damage to o-rings
    Sorry, all this stuff is labour-intensive.
  24. Qavion
    14,269
    Ian Riddell
    Before you start doing voltage and resistance checks on the valve, you might be able to hear/feel the F1 solenoid valve clicking. It should click just as the main hydraulic actuators reach full retraction (roof closing).
    If you decide to clean the valve, you might be able to soak the solenoid plunger in some kind of solvent overnight. That's what most seem to do for these kinds of actuators. The professionals probably have ultrasonic cleaners. If there are o-rings, of course make sure they are resistant to the kind of solvent you are using or remove them before soaking.
