Hydraulic leak on 430 | FerrariChat
Discussion in '360/430' started by kurtflies12, Nov 28, 2016.
  1. kurtflies12
    kurtflies12 Karting
    Aug 13, 2015
    64
    Tx
    #1 kurtflies12, Nov 28, 2016
    While under the 430 we noticed a hydraulic pump weeping a little. Can anyone give me a part number for the copper washers?
  2. Turbotuner20v
    Turbotuner20v Formula Junior
    Mar 18, 2014
    362
    That is the gear shift actuator unit. If you remove the banjo to replace the copper washer you will need to have the system bled by a shop with an SD3 or Leonardo.
    Depending on your level of comfort, a slight 1/8th turn of the bolt may snug it enough to stop the leak. Do not over tighten.
  3. kurtflies12
    kurtflies12 Karting
    Aug 13, 2015
    64
    Tx
    thanks
  4. Zapien1
    Zapien1 Rookie
    Jun 11, 2016
    8
    I have that same problem .. My mechanic said they don't make that cover and the only way to fix is by replacing unit which is 10 grand isn't that insane !!!
    So I'm just going to have that cover made
  5. Denzel Yang
    Denzel Yang Rookie
    Feb 2, 2023
    49
    China
    Denzel Yang
    Have same problem, is crazy farrari doesn’t sell the cover alone
  6. GogglesPisano
    GogglesPisano F1 Rookie
    3,213
    East Bay, California
    Joe
    #6 GogglesPisano, Apr 11, 2023
    Just noticed the same leak on mine from one of the banjo bolts. barely a drop though. Went ahead and purchased a new dust cover as well since mine was showing it's age. Best place to get a replacement is here: https://www.sequparts.com/product/actuator-dust-cover-ferrari-f1/
    Does anybody know if a flush is needed to replace the cover or is it simply a dust cover as mentioned?
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Not sure you would need an SD3, i would think it would bleed using the valve and clutch mounted bleed valves and changing gear on the paddles. You also have the 3 screws on the actuator block
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
  9. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    Seems like the OEM plastic part fails 6 out of 5 times, so I just ordered one of these covers from sequparts to keep in my hoard of spare parts...
  10. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    I would think with all the heat in the engine bay, you wouldn't wan't an additive 3d printed plastic part. They generally aren't the best in high heat.
  11. 24000rpm
    24000rpm F1 Rookie
    can print in Nylon, stainless steel or Aluminium alloy, even some exotic metal.
  12. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    So non-home 3d printers... at that point unless you have a CNC machine at home, it's easier and maybe cheaper to just buy the sequparts one.
  13. AandSC
    AandSC Formula Junior
    957
    Jax, FL
    Allen
    I’ve had this same leak since I bought my 430. I replaced the crush gaskets during my first annual and bled with my Launch. The leak persisted though. Just a couple drops every year so I don’t feel as if it’s worth replacing yet. But I’m curious if the dust cover issues noted above can allow the fluid to drop out the dust cap?? If so I’ll plan to buy the Sequpart cap.
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Try a Dowty seal if the copper washer is no good
  15. Denzel Yang
    Denzel Yang Rookie
    Feb 2, 2023
    49
    China
    Denzel Yang
    You
  16. GogglesPisano
    3,213
    Joe
    me?
  17. Denzel Yang
    Denzel Yang Rookie
    Feb 2, 2023
    49
    China
    Denzel Yang
    Is a typo, thanks for sharing.
    GogglesPisano likes this.
