Hylomar Gasket Sealer | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by enio45, Jun 19, 2019.
  1. enio45
    enio45 Formula 3
    1,678
    Gilbert, AZ
    Ed
    We are getting ready to install the heads on my 250 engine for the Ellena -
    My engine guy and i were talking about gasket sealant and we were wondering what then the opinion of using Hylomar Gasket Sealer for the heads and other areas. The Head gaskets will be sealing the
    oil and water passages as the cylinders are sealed with the fire ring type gaskets.
    Thoughts - advise etc?
  2. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,068
    Ed: why would you use the old style "fire rings"? One piece gaskets have been available for at least 35 years now.
  3. enio45
    enio45 Formula 3
    1,678
    Gilbert, AZ
    Ed
    well that is what i was led to believe the best way.....having said this, the machine work is done and the gaskets, firings are procurred
    if this is drastically wrong, and is correctable with the different gaskets, pls let me know
    otherwise - we would like to use the best recommended gasket sealer......
  4. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,068
    PM sent
