Hyper-Technical: 348 Performance Chip Programming Review
Discussion in '348/355' started by No Doubt, May 16, 2007.
  1. vvassallo
    vvassallo F1 Veteran
    8,032
    Palos Verdes
    Vince V
    That engine is different. I believe it has a slightly higher compression ratio and a slightly higher rev limit.
  2. powderbomber
    powderbomber Rookie
    Sep 5, 2009
    23
    thanks mate, we definitely agree there - I know for sure it is different, but what Im trying to find out is exactly how and why its different!
    Ive got some information from other GTC owners and parts manuals showing different exhaust headers and other parts - and Ive heard rumours of either different ECU's or different maps so im trying to confirm whether that is correct or not. Ive looked up the bosch part numbers and found that the ECU's are motronic 2.7's so now Im hoping to concentrate on the maps - maybe dumping them to disk and comparing with a stock GTB/GTS if thats at all feasible.
    thanks again
  3. vvassallo
    8,032
    Palos Verdes
    Vince V
    Considering the higher rev limit, the chips in the ECUs should be different than our Spider/Challenge/Serie Speciale versions. But I would think that's all. BTW, my SS rev limit is 7500 with fuel cut off at 7750, at least that is what I measured on the dyno. Thi sis supposedly 250 rpm greater than the other cars. Your compression ratio is 0.25:1 greater than ours. Also, your upper intake plenum is slightly taller.
  4. test3090
    test3090 Rookie
    May 25, 2011
    6
    Southern California
    George Hatzakis
    #104 test3090, May 10, 2012
    First of all I would like to thank you ALL for the great insight you provide. I have an 89 348 TS with Motronic 2.5. Would I be able to upgrade to 2.7 by simply swapping the chips? If so, can somebody please send me the BIN file from a 2.7 (or any pertinent info as to where to locate it)? Have searched around (google) but couldn't find anything. Thank you so much.
  5. 3forty8
    3forty8 F1 Rookie
    Rossa Subscribed Owner
    Apr 25, 2006
    2,568
    San Diego
    Eric
    Unfortunately, no, simply swapping chips will not upgrade the system. The way the throttle position sensor(s) operate between the two versions would be one system that wouldn't work correctly, and I'm sure there are others.
  6. test3090
    test3090 Rookie
    May 25, 2011
    6
    Southern California
    George Hatzakis
    Thank you so very much for your prompt response! Still, if I could have the BIN file of 2.7, I might have been able to make some comparisons and get some ideas about possible modifications - at least (saw pertinent links - do not mean to re-invent the wheel). Thanks again!!!
  7. Tired of seeing this ad? Upgrade now
  8. 355rockit
    355rockit Formula Junior
    860
    San Diego, CA
    Vas
    See post #96 in this thread.
  9. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,568
    San Diego
    Eric
    I would imagine the fuel maps, etc, would be quite different in the 2.7 355 chip vs. the 2.7 348 chip, but it would be one way to get that higher rev limit us 348 guys are looking for, lol! Let's get Ernie to try it on his car, yeah that's the ticket! :D
  10. test3090
    test3090 Rookie
    May 25, 2011
    6
    Southern California
    George Hatzakis
    I have seen post 96 and downloaded the file. Thanks for pointing this out in any case. I guess the "very similar" scares me a bit (as opposed to "identical" which would have sounded more reassuring).
    On another note, would an early (e.g. '90) 2.7 be any different from a '95 2.7, within the same flavor/model? In a few words, have there been any "minor" revisions, yet insignificant to constitute a major change (e.g. 2.8/2.9 etc)? Thank you for your time.
  11. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,366
    United States
    JM3
    Since this is back up after 2 years, does anybody have a bin file from a F355 Challenge 2.7 yet, or a chip I could borrow for a day?
  12. Llenroc
    Llenroc F1 Rookie
    Jun 9, 2004
    2,898
    In a Green House
    Vern
    There isn't any difference in the ECUs for the road car vs. the challenge 355s so the bin file would be the same. Remember the challenge series was a race against drivers not cars, ie; the cars were identical. There were two spring and sway bar options but that was about it for adjustably. The engines and ECUs even had seals on them to prevent tampering from factory specs.
  13. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    20,960
    The Brickyard
    The Bad Guy
    :D
    Hardy har har wisecrack. :p
  14. Tired of seeing this ad? Upgrade now
  15. test3090
    test3090 Rookie
    May 25, 2011
    6
    Southern California
    George Hatzakis
    #113 test3090, May 11, 2012
    Sorry for resurrecting this old thread but only recently I became an owner of an '89 348 hence these messages. If I may, a few points:
    1) It is definitely very intelligent deriving the SPC files for the 2.5 and 2.7. Thanks so much! Did you happen to encounter any revisions within 2.5 or 2.7 (on a 348 always)? In other words (thinking out-loud), would an "early" 2.7 look "identical" to a "late" 2.7? In support of this thought I noticed that your SPC files have alternative offsets (albeit commented) - but, does this suggest a possible change in offsets only or the value of registers as well?
    2) Did you attempt to actually perform any changes and try them on a vehicle? And if so, which ones would you advise to be "safe"? For instance, would raising of the "rev limiter" be advisable? Would you be willing to share (for a fee) some "optimal" profiles (as per your liking/experience/subjectivity) with the rest of us? In another thread I read a "debugged review" of an aftermarket "performance" chip using conspicuous programming e.g. jumping to certain registers thus by-passing a set of commands (with unknown/un-verified impact).
    3) In any case, do you happen to have the original BIN files for 2.5 and 2.7 that you used to derive the SPC files? If so, would you please kindly share them with me/us?
    Thank you so very much for your insight and time,
    George
  16. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,366
    United States
    JM3
    I know that is what everybody said, but I have also heard many times that there were/are special chips.
    If I could borrow one, it would be win/win, we would know if "the challenge chip" has the same rev limit as the standard chip, or have a quick location for the rev limit in the bin file. (not that I want to raise the limit, but once you find that, it makes it easier to find other locations)
    I can't say more.
  17. No Doubt
    No Doubt Five Time F1 World Champ
    May 21, 2005
    51,185
    Vegas+Alabama
    Mr. Sideways
    I sent the .bin's to Plugzit who can post them here if desired.
  18. Llenroc
    Llenroc F1 Rookie
    Jun 9, 2004
    2,898
    In a Green House
    Vern
    I'm not sure how better to say this but, there just isn't one. Both of my ECUs have seals on them and my redline is the same as the road car version. This was done to stop any tempering, before each race the ECUs could be swapped form one car to another just to insure there was no advantage to tempering. The parts book does not show any other units and the rules do not allow for anything other than the stock units.
    If there was ever a chip that changed the redline it wasn't used in the challenge series and in did not come from Ferrari.
  19. ants2au
    ants2au Formula Junior
    Nov 19, 2003
    689
    Sydney Australia
    Anthony
    #117 ants2au, Sep 20, 2012
    Sorry to dig this thread back up, but I am thinking of an ICE for the 256/512 eprom
    http://www.eetools.com/index.cfm?fuseaction=product.display&product_ID=314&ParentCat=20
    I suppose for it to be useful, it would have to response at 90ns, so you can tune realtime.
    Would that be a correct assumption?
    Oh we would want two of them, to do that.
    Oh, and another idea I have is to use a EEPROM instead of a EPROM, if you intend on fiddling alot with the program/data. But thats another topic. Apparently doable.
