Hyperflow Cats installation help for 348 Spider | FerrariChat
Discussion in '348/355' started by 348Spiderguy, Jul 12, 2005.
  1. 348Spiderguy
    348Spiderguy Karting
    Jul 5, 2005
    160
    Palm Beach Florida
    Eric
    I just ordered a set of Hyperflow cats today from Ricambi. Can anyone give me some info on installation on my 348 Spider? Things I should look out for. I am mechanically inclined and have a good set of tools including air tools. Thanks for your help.
  2. evansp60
    evansp60 Formula Junior
    Nov 2, 2003
    384
    Ottawa, Ont. CANADA
  3. 348Spiderguy
    Jul 5, 2005
    160
    Palm Beach Florida
    Eric
    Thanks for the pics. It looks like a big job. Do you have to remove the mulfler?
  4. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    I have installed with the muffler in and out. A bit tight with the muffler in but doable. Not a bad job either way. Regarding tools, if I recall correctly all I needed was 13mm for muffler clamp bolts and nuts, 10mm for the thermocouple and 22mm for the O2 sensors. Good luck!
  5. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    Muffler out will be A LOT EASIER...Some of those clamps are tough to get too and with the muffler in you have hardly any room to work with. Do it with the muffler and airbox out, a lot easier though a lot more time to do it...relax, take your time and do it right. When you put the O2 sensors back on, ground the housings so that you will never have the "CEL light because of bad O2 ground" problem.
  6. henkie
    henkie La Passione...
    Apr 13, 2005
    10,516
    Deil,The Netherlands
    henkie
    Is the gain from the hyperflow cats worthwile ?
    No further adjustments neccesary ? Motronic regulates itself ?
    Thanks.
  7. PassionIsFerrari
    Aug 15, 2004
    2,454
    Gain is minimal. Maybe 10 horsies despite all claims...not a enough to make it a big deal
    Engine not catching on fire because of bad ceramic cat design = priceless.
    No other adjustments needs...Motronic does its same ol thing'.
  8. Ricambi America
    Sponsor Owner
    I'm biased, but I think gain is more that 10hp. More importantly, I feel the throttle response is improved, exhaust temps are WAY lower, and improved sound.
    If you believe these dyno results -- and even if you grant them a 25% margin of error, the gains are more than 10hp. http://ricambiamerica.com/hyperflowdyno.htm
    Yeah, I know we could launch into a big debate about this dyno test, but for now, it's the only "real" data point we can work with.
  9. tclark
    tclark Formula Junior
    Jun 4, 2004
    604
    Mechanicsburg, PA
    Tom Clark
    Tmobileguy, can you post a pic showing how you grounded your O2 sensors.
  10. PassionIsFerrari
    Aug 15, 2004
    2,454
    I'll try to get a pic up...Just got whacked by a hurricane so the stuff that I have left is everywhere....still have the Ferrari though...will try to get a pic up but here is a simple explanation...
    1. buy 2 hose clamps from a parts store that would be the correct size to go around base of the o2 sensor (about twice the circumference of a tube of chapstick)
    2. Strip off the ends of 2 wires, I used 12 guage wire...
    3. Clamp the hose clamps over the stripped end of the wire, thus clamping the wire to the o2 sensor...the other side of the wire I crimped to one of those "C" looking end fasteners. I then fastened that to existing bolt on the chassis nearby by just unscrewing the bolt a little, sliding that in, and then re-tighting the bolt....
    very easy stuff....took about 10 min. on each side...
