Hypothetical: Breaking Into the Trunk (Engine Bay) | FerrariChat
Discussion in '308/328' started by mwr4440, Sep 27, 2021.
  1. mwr4440
    57,969
    Bavaria, The 'Other' Germany
    Mark W.R.
    A 3x8. Not a GTB4.
    Trunk Pull does NOT WORK. Emergency does not work.
    You have to:
    DRILL INTO the luggage area, or
    BASH OUT a tail light,
    To reach the wires to open the rear engine bay.
    Where do you:
    DRILL OUT the bottom of the truck, or
    WHICH Tail LIGHT to Break,
    To cover ALL possible contingencies?
  2. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,327
    Montana
    Kim
    If it was me, I’d break them all out. Sorry, couldn’t resist :)
    I was able to get the emergency release cable to open the decklid on my old GTB QV after the regular cable snapped but to do so I had to get a pair of vise grips‘s on the cable and Pull like a beast which finally pulled both latches open.
  3. BigTex
    79,380
    Houston, Texas
    Bubba
    Pressuring DOWN on the lid also sometimes lessons the release effort..
    Man I would hate to smash a good light as they are expensive.
    Muffler removal likely, to hole saw into the trunk floor, but a more hidden repair......
  4. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Pfft hold my beer, put a hole behind the license plate, cheaper to weld it back up then pay for 1-2 lights
    SAFE4NOW and Brian Harper like this.
  5. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I recall there's a thread on this and someone already did this. Broke a light to get into the trunk, and it was successful.
  6. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    REALLY? Surely there's a better way other than destroying parts to get in there!!!! OK, I admit I don't know but I'm not sure I could bring myself to break a tail light on my 328 to get the hood open... :eek:
  7. 308 milano
    Jan 15, 2007
    5,327
    Montana
    Kim
    I’d get a pair of vise grip‘s on that emergency cable and have someone push down on the rear deck lid like big Tex suggested then pull like hell on that cable. Nothing to lose. That’s what it’s there for and worked for me. I’m with Mike on this. Not a fan of drilling, cutting or smashing holes in the car.
    330gt likes this.
  8. dinoart
    dinoart Formula Junior
    798
    Westminster CA
    David
    Hey Mark
    You can look up my old post. It happened to me exactly about two years ago. After replacing a new cable, I failed to tighten the nuts to secure the cable and shut the lid. That was a dead sentence. I waited at least 3 days to think about it and finally decided to bust the passenger brake light. I used a Dremel cutter with a disc to cut the lens off, remove the bulb & housing assembly, accessing the cable, pulling it with my bare hand or pused it with a screw driver I don't remember. Looking back, I think it was the least damage you can do to the car and the cheapest. Luckily I found another used brake light assembly on Ebay for $100.
    pshoejberg likes this.
  9. dinoart
    798
    Westminster CA
    David
    On another note, the reason I decided to cut the passenger lens was that the emergency cable ends at the first latch while the main cable runs all the way to the passenger latch. So pull on the passenger latch cable where the cable ends will open both latches.
    Good luck! May the force be with you...
  10. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    If you remove the rear left wheel and the fiberglass fender lining and look up under the fender, you can see the tubes where the trunk release cables goes through. Carefully, you can use a dremel to cut a small piece of the tube to expose the cable, you can then grab the cable with a hook and pull it with a pliers or a vise grip. I guess this only works if the cable breaks at the release lever or somewhere pass that.
    mike996 likes this.
  11. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,832
    Dallas Texas
    If you know you know
    or put a rubber grommet in the hole for when it happens again. LoL
    S
  12. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    I think the rear panel is fiberglass?? That doesn't weld well. Maybe its metal, I can't recall.
    I would take the inner rear fender out and locate the cable, and maybe cut into that first, as the failure may be forward towards front of car.
    Doug
  13. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    #13 Mule, Sep 29, 2021
    Both the main cable and emergency cable run through a tube/pipe from the latch, makes a 90 degree turn then exit before the left latch. The emergency cable ends there, and the main cable continues to the right latch.
    The cable rarely fails; it is most likely the lock nut on it has slipped, and you can't pull enough. The lock nut triggers the latch to release when pulled. If you remove the latch screws and pull the whole latch and cable, you may release it by gaining more distance of pull.
    Looks like this. The lock nuts are barrel tubes that slide onto the cable and have a allen screw go into the side to press the cable.
  14. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
