360 - I am chasing down cel P0116 and could use some help - Anyone dealt with this? | FerrariChat
360 I am chasing down cel P0116 and could use some help - Anyone dealt with this?
Discussion in '360/430' started by carguy007, Apr 19, 2020.
  1. carguy007
    carguy007 Formula Junior
    Apr 24, 2013
    892
    I am chasing code p0116, which relates to the signal of the coolant temp to the ecu and dash gauge. It indicates that the signal from the coolant temp sensor is outside of normal parameters. I did do a search and could not find much of use. I have ordered the sensor. I don't think it is a thermostat issue as the car warms up properly. Any help, or anyone that has worked through this and can offer advice would be great.
  2. 24000rpm
    24000rpm F1 Rookie
    Aug 31, 2012
    4,653
    China and California
    thermostat stuck closed will warm up properly no problem, but will overheat the engine. Thermostat stuck open will warm up too, just a little longer when stationary.
    thermostat will not throw a code.
    I am bettering coolant sensor, instrument cluster wire, coolant sensor wire
  3. carguy007
    Apr 24, 2013
    892
    Thanks - I am going to start with the sensor and see where it goes from there.
