I am gonna do the gear oil switch ... and prove which is better | FerrariChat
Discussion in '348/355' started by rskdsk, Oct 21, 2009.
  1. rskdsk
    rskdsk Formula Junior
    Jun 1, 2006
    527
    Ok ... I have done the reading within this forum and last year I changed from the stock gear oil to redline 75w/90ns. This change did make a small improvment in shifting, but nothing worth writting home to mom about! Today I took the plug and ordered the redline superlight weight and friction modifier. I should have this stuff sometime late this week or early next week ... I'll make the change and post the results.
    My car is a 94 spider with 57K ish miles and the original unmodiied tranny. I have the typical cold shift issue with 2nd gear, and a slight notchyness when shifting fast at high RPM's through the gears when warm ... normal rpm ****ing is fine when warm.
  2. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    Good man, thats what I use in my Ferrari and I dont use the friction modifier. :):)
    Looking forward to hearing what you think. Comparing the Superlight stuff to the NS. :D:D
  3. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    I use Superlight with fiction modifier and love it. :D:D ... just to complicate matters.
  4. Ricambi America
    Sponsor Owner
    Superlight Shockproof in mine. :)
  5. rskdsk
    Jun 1, 2006
    527
    There seems to be quite a split in what people are using, and the results they are getting. When I put the ns into my car, people where raving about how good it was ... I have not had that experience ... better yes, but nothing like butter. Now I am gonna try the shockproof ... everyone claims that is the cats meow ... I'll be the judge of that soon enough
    Someone should put a survey up ... all the different gear oils and the results ... that would be a worth while survey!
  6. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    Problem is most hold to their views on oil like they do on the type of women they like. It took a lot of pushing to get me to try Royal Purple for one of my race engines the first time. Same with adding Redline to the 348 gearbox. It was kind of like when I switched to Asian women, will never go back again and could not believe I wasted my time with the other brand ;).
    --Mike
  7. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    I am not sure what was in mine prior, but I switched to the RedLine 75W90NS and noticed a major difference. There is the odd time that it isn't pefectly smooth, but most the of the time it is and I am satisfied. I would like to know the comparison between that and the Shockproof, which I hear is excellent.
  8. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    I went with the Redline MTL (GL-4) in my 348 and it was really a big improvement. The second gear shifting was not super slick when cold, but it would go with a little effort and a slow shift. Once warmed up all the gear shifts were awesome!
    BT
  9. mcooper
    mcooper Karting
    May 13, 2009
    108
    Dallas, TX
    I recently put the Superlight Shockproof in and had very positive results.
  10. rskdsk
    Jun 1, 2006
    527
    Did you put in the additive?
